well things keep getting better and better....
thought id finally take my car down today to get some secondhand front tyres and a wheel alignment so the car would be pretty much ready for sale.
*sigh*
no such luck...
they took the rims off and one of them is cracked... the other buckled, which is why the steeringwheel shook so much, not the alignment.
so one rim is not reparable... the other is a waste of time... so back on go the stockies with enough tread to get a roadie so i can sell it.
getting rid of it for sure now... had enough.
https://www.sau.com.au/forums/topic/35170-fuk/
man what a **** tard....
he tells me all this and then he puts the secondhand tyres on them anyway!
so he charged me 200 more than what it should have been... why would i want second hand tyres on a pair of rims that are ****ed?
i cant be bothered going back down there right now cause ive spent the last 2 or 3 hours there!
i'll just ring him and ask him if i can doit on monday.
ash - the stockies look shite under the GTR guards.... they sit in too far...
now my car looks like a wanna be drifter with the 17s on the back and the 16s on the front.
https://www.sau.com.au/forums/topic/35170-fuk/#findComment-702817
well this just gets batter and better...
i just rang the **** knuckle up and he wont take the tyres back...
he claims he asked me what i wanted to do with the wheels and tyres and i just said "chuck em in the boot" which i did say... but he didnt say they had their ****ing tyres on em.
now the cun! wont take them back.
if ur in the SE Burbs and want tyres or wheels dont go to ********** ***** they're a bunch of fu(ktards...
the only good thing to come out of this i spose is that my wheels were at least ligned properly.
https://www.sau.com.au/forums/topic/35170-fuk/#findComment-702859
LOL bill...
well i guess this means i wont be coming on the cruise tomorow... cause i aint got enough cash... they will have to feel the wraith of my aunty and her lawyer type cut throatness... i have a feeling i will be getting my money back :P
https://www.sau.com.au/forums/topic/35170-fuk/#findComment-703021
LOL bill...
where and when is the cruise tomorrow?
https://www.sau.com.au/forums/topic/35170-fuk/#findComment-703055
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
