This cant be a serious question.
check the Events Section mate... the 7 page cruise thread that myself and a few others have spent 6 weeks oranising!!!!!!
READ THE EVENTS SECTION!
sorry man. i've not long been a member of this forum. still finding my feet. and yes i was serious.
https://www.sau.com.au/forums/topic/35170-fuk/page/2/#findComment-703364
i didnt crack the rim... those dipshits at that place in question on warrigal rd in cheltenham when they took the tyre off... how couyld i drive around on a rim for 4 months that had a crack that stopped them from being able to fill the tyre with air?
https://www.sau.com.au/forums/topic/35170-fuk/page/2/#findComment-703880
fken bastards then!!
i swear some ppls egos etc are just fked up.
Like when they break something they just leave it and not tell you, or say it was done before you got there
As i was buying the car i own now, i got RACQ to do a test, they ****ing screwed up the thread on 2 of the wheels studs on the front. I know they were fine because i checked them earlier that day!
bastards
https://www.sau.com.au/forums/topic/35170-fuk/page/2/#findComment-705358
I think I know the place.... (is it blue)????
I went there for a wheel alignment, and the fu(knob got pissed off coz i just bought new tyres from someone else.......
I told him I needed to get to work by a certain time and that i would be there 8am, and he didnt even touch the car till 8:30 - 8:40......
At one point, I wished I had my samurai sword in my boot so I could slice all his tyres to shreds...
He was such a smart arse, and while I was there, he tried to rip off this old man by selling him a tyre worth less than the ones I got, for OVER 3 TIMES the price, probably b/c he drove a merc.....
They wont get my buisness again... I'm suprised they are still in buisness....
DISCLAIMER: The opinions expressed above are mine, and in no way reflect the opinion of SAU :D
https://www.sau.com.au/forums/topic/35170-fuk/page/2/#findComment-705493
cool... sometimes questions like that aren't serious.
just checking.
have a look at the -cooldown from the GOR.
excellent day.
https://www.sau.com.au/forums/topic/35170-fuk/page/2/#findComment-705935
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
