Ok my new car, after getting rid of my R31 skyline.
R32 GTST sedan
first dyno run was 136RWKW @ 14psi (stock turbo, auto, 3" exhaust)
2nd dyno run was 138RWKW @ 7psi (r33 turbo, 3" dump added)
fastest dyno run 15.3 @ 90mph (stock turbo, auto)
When i picked up the car in mid 2011, it was pretty stock apart from the following.
front strut brace
RS*R lowered springs
pod filter
3" cat back RS*R exhasut
3" high flow cat.
type m body kit
since then i have added the following,
turbo tech manual boost controller
3" split dump pipe and front pipe (one unit) from CES racing.
drift boost gauge
https://www.sau.com.au/forums/topic/351703-r-tunes-skyline-20/
Ok an update.
the car now sits as a shell waiting to get painted gunmetal grey.
I have brought the following.
2nd set of GTST rims
a set of R33 GTST and GTR rims
blits vented bonet (for GTST)
vertex body kit
rear strut brace
nismo leather gear knob
nismo radiator cap
nismo thermo stat
better condition rubbers (all doors), so the ones on the doors, the cahssie, and the one that runs along the top.
better condition c piller trim
excedy clutch
adj caster arms
cusco zero 2 coil overs
rear cradel pinaples.
better condition manual gear lever surround
manual gear lever cover
better condition blanking plates and demister vent. (the ones at the very front of the dash)
blits SE FMIC
R32 GTR spioler
clear indicators
new hand brake cover
project mu handbrake shoes.
hicas lock bar
new driver window switch as i broke two of the micro switches.
  • 3 weeks later...
Ok brought more parts.
project mu brake shoes (for the hand brake)
white line GTR adj sway bar (also got the front in the deal but may have to get rid of it)
just jap hardend tie rod ends.
4 X r32 gtst rims
4 x R33 gtst rims
Im waiting on pics from my wife so i can put them up
And thanks to the cyclone that hit darwin i will defently be needing a new interior as it got wet and now will get modly as all the windows are out in waiting for paint.
If any one has some R32 GTR or bucket seats please let me know.
Hey guys,
Got the rubbers of the for sale forum from another member who is wrecking his car, had a look at the pics and the rubbers were in better condition then mine. ill pm you the price.
With the side skirt yea thier up for sale, as is the whole body kit. Send me a pm.
Also have some pics not the best but my missus took them.
  • 4 weeks later...
Ah k time for a update,
Have brought the follow,
Rear camber arms
alloy 52mm 2 core radiator
the blits FMIC as mentiond above (had to wait for it to arive at just jap)
pair of recaro look alike seats and rails (from just jap) in black cloth
HEL ADR aproved brake lines
New center vents
clear indiactors
catch can
SRI solid bush for stering collom (in one in side eng bay) and got it for $29 inc postage from just jap.
push start button kit
N1 water pump.
Will be able to start building it very soon, so some good pics to come.
  • 2 months later...
Ok update time,
Car has now being painted and body kit fitted, a big thanks to the guys at arafura crash who did the work. and so you know the paint is the factory paint colour, light mertalic grey.
So far pulled the rest of the interor out so i can clean it and get it retrimed.
b piller brace fitted. one question for people that do have one have you use one or two bolts to secure it?
dummy place the driver seat and harnes.
fitted all coil overs
rear strut brace
rear sway bar
rear camber arms
all brake lines
rear hand brake shoes
front sway bar
fitted the blits FMIC
fitted the nismo radiator cap
clear indicators fitted
new center vent and demister vents fitted.
fitted the 33 rims, so i could get it on the truck. they make the front bar sit a 150mm and the stock 16" the front bar was at 100mm
Needs a GTR grill retrofit and align the headlights with the indicators, otherwise it looks kinda unproportioned imo.
The 33 rims are a full 10cm larger then the 32s? that doesn't sound right...
Yep still have to fit the headlights proberly. im running 235/45/17 tyers on the GTRs were the stockies were 205/55/16. diffrent brand tyers are also diffrent sizes. And also not changing the bonnet as it ADR aproved.
Edited by R TUNE
Lol if different brand tyres were different sizes we'd have a huge problem. That's why we have standardised size ratings. 235/45R17 is only 12mm larger then 205/55R16. It would only raise the car 6mm. Hardly 50mm now isn't it!
Edited by TMM
  • 5 months later...
Ok time for a update and i know it's been long.
Car is now on the road and regersted.
power is currently at 160RWKW still with the auto tune.
have taken it to a drift day and fark it was awsome but still got to work on the suspention set up.
Do have new pics but having trouble up loading.
Well got the car back from the tuners and managed 160RWKW @ 14psi. not bad considering it;s darwin wet season (temp 28-34 humidity 60%-90%).
ill post the dyno graph when i get a chance.
Im alos removing the ATS 2 way as it sucks for street driving, it fine for track use or weekend use. But for street just shim a stock LSD.
  • 5 months later...
Time for an update, Last update was after RD5 of the burson auto parts drift series up in darwin, at hidden valley raceway.
I cooked the cluctch, enough that i had 3 big cracks in the fly wheel.
The gearbox has said enough with all sycros crunching and bearings been noisy.
So replaced these, new fly wheel, 5 puck cussion button clucth from RPM replacement gear box.
tryed fitten a Z32 afm, as my tunner thought it was the problem with my car not starting, stalling, running like crap. In the end the AFM was dirty and the pod ( a cheap crap one) had cloged (i also found later the intake pipe to the turbo was not on.
My tunner couldn't get the Z32 to work even tho he got it running with the stock AFM and didn't tell me as my aim was to get it running.
I painted the R33 GTR rims black.
Had to replace the rocker cover gaskets as they had been leaking, and also suffed some serious blow by, after competeing in the burson autoparts drift series RD 1 2012.
At that event placed 5
I found that i had understeer in my current set up, and was selecting 5th insted of 3rd on turn 7 due to a worn gear leaver bush.
Also had issues with blow by, and a leaking rocker cover gasket both now fixed. but looks like the turbo seal has gone as im blowing white smoke on back off.
Any way here are some pics
Fitted a fire bottle, painted the rocker cover, painted the GTR rims.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
