the parts;
r31 with rb26/30de
gearbox is out of a series 1 r31
5.5kg chrome molly flywheel
has a extreme heavy duty cushion button
clutch/ motor maybe done about 1200-1500kms
the story;
Monday;
went to leave work noticed puddle of brake fluid under car, the clutch slave cylinder boot had leaked.
bought new slave cylinder, fitted, bled (with hose from nipple into another bottle of break fluid)
drove it around was ok, turned it off packed up tools went to leave work and wouldnt go into gear.
bled the clutch again.
no change.
adjusted pedal removed all play (next to no thread left towards pedal side)
if i started it in gear it would shutter then launch
if i started it in gear with clutch in it would squeel as it was kicking over
bled it again was a bit better
a couple minutes after leaving work, it got difficult to change or put into gear. then started to really drop in revs and making the car dive with clutch in
by time i got home i was pretty much smashing the gears, stalling at lights
Wednesday
Replaced the master cylinder with the r32 master cylinder
bled it from master and slave
so far
starts then it might go into gear eventually, might work easily might not
starting in first gear hand brake down clutch in, it has creeped forward but not everytime
starting in reverse doesnt move
i'm thinking damaged spigot bush
https://www.sau.com.au/forums/topic/351807-clutch-issue-works-then-doesnt/
Bent fork not pulling the clutch all the way? Heavy duty, esp extreme heavy duty, put alot of load on the pedal and fork.
^^It's a possibility.
Did the clutch work fine when you found it leaking before you changed the slave cylinder?
Give it another bleed just for good measure and see if it improves.
it was working fine then the 2 days before hand it was getting hard to put it in gear
bled it again, tried adjusting the travel in the pedal, its got 12-14mm of travel
now it;
goes into reverse everytime no issue
struggles to go into first on some start ups
goes into 1st 2nd 4th and 5th without dramas after a drive, but crunches/ clunks into 3rd
when coasting along if i put clutch in then back out it "shutters" around the clutch point
Do you still have the solid line in it with the rubber section at the bottom? If you pull the fork boot off the bellhousing can you see any damage inside? I think your pivot point has broken
update
was going ok got about a dozen gear changes then... it got stuck in 3rd.
Turned it off, still stuck in 3rd, got it out of gear eventully.
Now cant find any "slot" or gear other then 1st 5th and reverse
it eventually went into 1st with engine off, turned the key without the clutch in, it jumped forward, i kicked the accelerator and it moved without the clutch
with a bit of effort i did a 3 point turn, got back to the mechanic using only 1st gear
he thinks either the springs have broken in the clutch plate or the gear box isn't strong enough for the motor
update
He's talking shit when he says the gearbox might not be strong enough for the motor when referring to your problem. The fact that you jump forward when you try and start the car with the clutch in cleary shows that it's a clutch related problem.
Ask to see the clutch plate and pressure plate if he pulls them out.
Edited by Dobz
he works a couple doors down from my shop, he always shows old parts even fluids.
he is more possitive something broke on the clutch plate
but thinks it might be the gear box cause its not selecting 2nd 3rd or 4th at any time, and 1st 5th and reverse are time consuming to force in
we'll see eventually
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
