there are differences in the cut, as 33 &32 GTR bumpers are different in their angles
"universal" ones will not fit both or any that well tbh.
the ones we do are made & sold here in Japan, for each model (not the 34 tho)
cost $170 shipped if your a SAU member :)
normal price is more like $200
if you want a set all i need is
full name
delivery address
email address
contact number
car type
what is the sau price for r32 gtr n1 vents and intercooler surrounding in carbon?
Hey mate
I put some carbon N1 Vents in my front bumper on my R33 GTR, got some before and after shots for ya. I got mine from Just Jap, they fit ok but no where near as near as factory fitted ones. I reckon they would look pretty good on a s2, it would certainly be different any ways, stick out of the crowd a bit.
BEFORE:
AFTER:
The only tips i have would be mark it out smaller than you would normally as the plastic bumper is very soft and easy to cut, then i used a drill with a 5mm drill bit and drilled the out line of it, then used a hand file slowly bit by bit shaped it until they fit in nice and snug, then gave them a good dose of sika flex to keep them in. They were a bit of a pain to do but got there in the end, you will also have to cut holes in the reinforcement bar aswell with a angle grinder and 1mm cutting disc.
As for the door trims, from my knowledge all R32,R33 and R34 have the same Interior trimming, except for a few little things but yeah should all be the same.
  • 3 weeks later...
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
