hey guys - need some touch up paint for my C34 S2 in Pearl White.
has anyone had any success with getting pressure packs made up to suit this colour? or does it require a special application method?
just need to touch up a couple of stone chips, some flaking paint on the side skirt etc.
failing that does anyone know the paint code or where i can find it?
cheers.
https://www.sau.com.au/forums/topic/351961-s2-white-pearl-paint-code/
A quick search online has produced a code for an S15 Silvia, which may be the same...
W-K-0 (ZERO NOT LETTER O)
Alternatively, there's also another one for a 2004 Pulsar (Altima) - "Satin White Pearl Tri-coat: QX3"
Hope that helps.
Edited by Glitch
I have looked and looked and found nothing. Saw on "Pit" brand (Nissan OEM?) touch-up can for it which I think came from Japan; but none of the Nissan places I have called know of it or are willing to/can get it. I have also had no luck from the few specialist auto paint places I have called about having some touch-up paint made to mach - 'too hard' seems to be the response there. "Oh it's got 3 coats and it needs a pearl and a top coat... I'm not sure that can be put in a can". That sort of thing. I gave up long ago, and am living with the paint chips. Would appreciate any info' if someone else has more luck though :)
Hi, my Stagea is pearl white and i also painted my Exa race car the same colour, yes it is available with no worries and its not hard to work with but you need to do it with a spray gun etc as painting pearl has to be right.
I have a little mark on the front bumper that i am going to repair before the Marysville run so maybe if you are in melbourne you could try the paint brush way if they are small enough
Piant
cheers.
Paint code is on the plate on the bulkhead. Pearl white may be B2F5
hmm, i just want to get a set of eyelids painted, and then a couple of paint chips touched up.
not sure if its going to cost a fortune to mix up such a small amount.
thanks for the info though, guess i better go see my panel guy.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
