hey all been looking at some 260rs's and found a real neat 1 but found the blue nissan build plate says rb25det? guy told me all 260rs's say that as thats how they were originaly built b4 autech fitted the the rb26dett...
is this true?
jon.
Yes they are plated with rb25det.
https://www.sau.com.au/forums/topic/352170-260rs-q/#findComment-5647358
Sure these are all bolt on and changeable for people attempting to disguise a RS4 as a 260 but they are easy to check:
  • NO front cup holders
  • NO sunroofs
  • Under body front brace
  • Fork bottom rear shocks
  • Clutch master is recessed into firewall
  • Higher redlining tacho
Thats all I can think of atm, but as stated above the only way to do it is with FAST.
https://www.sau.com.au/forums/topic/352170-260rs-q/#findComment-5647754
Correct.
All 260RS Stags are plated as having RB25DETs. If you're ever in doubt you might be looking at/own a fake/converted 260, it should be manual, Brembos, and the recess in the firewall for the boosted clutch master are the first signs its a 260. There are other things to look for, but thats an easy start.
:thumbsup:
https://www.sau.com.au/forums/topic/352170-260rs-q/#findComment-5647870
ok cheers, didnt check the firewall recess but all else checks out.
still looking at this stage, the complexity of the gtr setup is a bit offputting as thinking towards future maintenance etc, thinking an s2 rs would be good also neo+2wd manual, alot less headaches???
jon.
https://www.sau.com.au/forums/topic/352170-260rs-q/#findComment-5647976
Hey mate I have the fast program and checked mine. Comes up witg a message saying "these are autech special vehicles" or something like that. If you want a VIN checked PM me and I'll check it for ya.
And yes I can confirm that they never came with RB26DETT on the plates. I'd be worried if it did. Autech recieved the bodys after plates were fitted, then installed the 26's.
And the no cup holders thing is present in all manual models from what I can remember ad they hit the gearstick.
https://www.sau.com.au/forums/topic/352170-260rs-q/#findComment-5648363
Recess for clutch does that mean you have power booster on clutch pedal? I have an R33GTR clutch pedal on my RS4T but no room for the power booster :(
Yes get an RS 260 if they are not too dear - worth it for the better brakes, stronger rear end and engine is easy to get a reasonable power increase. Get a Nistune chip, better dumps (don't know what exhaust they have but look at that) steel wheels for turboand a good ebc and wind the boost up. Stock they are a bit of a slug.
https://www.sau.com.au/forums/topic/352170-260rs-q/#findComment-5649170
clutch booster is gay. didn't bother when I did mine. is a pedal really that hard to push?
Yes - have a very heavy duty clutch. Not a problem on the road or track but can be a pain in the Auckland traffic as car is my daily driver. However am managaing without power assistance!!
https://www.sau.com.au/forums/topic/352170-260rs-q/#findComment-5649456
  • 1 month later...
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
