Cruise To Marysville.
Sunday 6th of Feb
10:30am meet 11:15am departure.
Monash University Clayton Wellington Road Carpark
Taking Maroondah Hwy Route Approx 1 hour 45 min drive.
Can westide boys pick a meet spot on the way to meet up.
Preferably someone who knows the area to pick a parking spot in the main towns area.
Avoid Tolls for those who dont want to take it.
This is a drive, not a race, drift contest, skid pan, or touge. if you wish to be a hoon, DONT!
Will have maps ready on the day, as this shit hole of a laptop wont allow me to link the map.
Please confirm so we can get some numbers.
cheers
Edited by AaronNM35
https://www.sau.com.au/forums/topic/352199-vic-stagea-cruise-6th-feb-2011/
  • Replies 58
IM there....
from the west aswell. so whoever wants to have a pre meet. i suggest bp on sharps road just off the freeway
give us a map location somewhere along the route so we know where to wait for ya
Hopefully see you there Alex!
I'll be at the Maccas on the corner of Sprinvale Road Wellington rd (just round the corner from the Monash meet) from about 9:15 if anyone is interested in a Breaky pre-meet.
sounds good lol..
macca's breakfast!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
