high i put new comp on my 32 gtr well second hand in very good nic
replaced with new o rings
put new reciever dryer on
i vaced it down for 6 mins prob should be longer
then gased it up wuth 600 grams
founs low pressure was reading right at end of dial when the car was running with clutch engaged
can someone please share there thoughts im off to adleaide on wednesday so bad timing
i suspect blocked tx valve in evap box ????
https://www.sau.com.au/forums/topic/352314-r32-gtr-air-con/
for a really high low presssure there is a blockage somewhere or the tx valve is stuck open all the way. i wish we copuld just put an orifice tube in there instead...
what was the hi pressure reading? and did the pressure drop when you reved it up?
https://www.sau.com.au/forums/topic/352314-r32-gtr-air-con/#findComment-5649314
so the low pressure gauge (blue) was reading high? how high? it could be that the compressor hasnt kicked in therefore its just resting pressure. a blockage anywhere will make the blue side go down. stuck open tx will prob go down to 40-60 psi. could also be that the clutch in the compressor is slipping. this will be seen as low side high and high side low and usually slips more with rpm. what was happening on the red side. should have vacced down for half hour but too late now...
actually you didnt fit the compressor backwards did you? S is for low side hose and D is for high side.
Edited by t_revz
https://www.sau.com.au/forums/topic/352314-r32-gtr-air-con/#findComment-5649460
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
