4inch exhaust will help although not really required.
im runnina hks superdrager which steps from 3.25" to 3.5" then 3.75" at the rear - over 400awkw
although, if i did fit a 4" i'd make more power - good bang for buck mod i think
what oil pump are u going to run?
  • Replies 43
Posted Images
Just because you make the power, doesnt mean much, we all know can "make" it if you force it.
You will probably find a 30-40rwkw gain soon as you swap your exhaust out and then that would bring you closer to 450, which is what you should make on RS's.
Given he has a 3", and lets face it, its gotta be changed - 4" is the simple choice.
this is true & exactly what my tuner advised - the exhaust is a little restrictive
the point im making is that its not a required mod BUT well worth it
Yea I will start buildin an exhaust as soon as I have the new engine in :) in the process of swappin my t04r turbo for something a little smaller ATM not sure of type yet just no he paid $3500 will find put more about it tomorrow
  • 3 months later...
  • 2 months later...
  • 4 weeks later...
Jack
Magnaflow and a few others do of the shelf 4in inlet and outlet oval mufflers in stainless for $380
I know because i bought one last week for my 30 26, also using wolf ecu, 1000cc id injectors, To4z, E85
haha even the comptuers on my side ;) cheers mate
Jack
i have talked with Difilippo and they will do custom size 4" in and out mufflers in stainless quoted at $400 rather than a take what size is closest to what you want off the shelf.
Jack
cheers mate are you running just the one muffler at the rear?
Building a 26/30 myself. Just wondering is the 26 head a straight bolt on to the 30 block. Or do you need to modify it to fit. What needs to be done?
do a quick search mate u will find pages and pages of info on what needs to be done
  • 6 months later...
so after a long while i got the motor in the car ::teehee: which im stocked with got a few little question
first is a barb that im not sure where it goes to see pic
second in my wiring for my alternator by the looks of it my mechanic cut the 2 wires going to it n the only 2 wires i can find in the loom that look they go to it arnt cut :S so it someone could let me know what they think n if there wires for something else let me know :D
last pic is just one of the motor pretty happy with myself done everything alone and first attempt at all this stuff :P
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
