  • Replies 58
More parts available
brake booster and master cylinder $220
Std Clutch and flywheels $100
Clutch slave cyl $65
Clutch master cyl $65
Edited by BoostdR
Hey matt. Im wanting to buy the passanger side door off your 33 GT-R $140 for the entire door ? 7054 Tasmania :/ lol. can pay extra for the trouble :) can i get a couple of photos of the door cheers :)
u mean the trim ? Is it straight u can keep the glass n handle or what not too save weight ill still pay $140 for the door can u pm me a couple pictures please ?
