ah ok i have pics of the RB30 which im told is the same as the RB25/26 but sorry cant confirm if the same as the ID2000, i don't see what would be so different though
  • Replies 163
Posted Images
here is an install guide from Simon Michealmore
>>Install into Neo<<
the injectors he used were full length ones the ones being supplied in the group buy a 3/4 length
So full length injectors require the 20mm spacers but they Neo injectors in the group buy don't?
I'll be in for a set of 60lb'ers for a Neo as soon as someone buys my 6boost manifold!
yes but its only the Bosch injectors that are 3/4 length but Simon in that thread has just bought the 80lb/h Siemens so spacing the fuel rail must be easy enough
Hey was just after a group buy like this, Well im looking at the EV14 1000cc Injectors for my R34 GTT a set of 6, Will these fit it up properly without height adapters or do i need them, Please let me know what wiring harness also i need to connect it up, i have a R34 GTT RB25DET NEO
I even want the Walbro GSS342 fuel pump, Can u let me know how much my total would be.. Cheers!!
hi Zaver the EV14 are a 3/4 length injector so you don't need height adapters
1x EV14 1000cc $580
1x set harness $66
1x shipping $25
1x walbro 342 $132
Total $803
steve if i get the id1000's do i need the height adaptors to run them with A/M fuel rail?
coz i would be down for a set of them!
sorry I'm not sure, I'm trying to find out
every time i think i have my head around injectors i find out i don't :D
i dare say you will but don't quote me :)
hey steve,
just double checking these will fit np with the stock plenum?? and ive already got a adjustable nismo fpr, so should be ok.
e85 here i come :)
oh, if its just a connection issue, should be ok, as there is a rubber tube between the rail and fpr, im sure ill work something out.
and since your going the e85 way, do only the three caltex servo sell e85?? i know there is that race shop that has it, but do any other servos??
there is a Liberty on Tapleys Hill Rd
are you familular with Simon Micheal mores S14 drift car with RB25 NEO engine
with a GT3076 and these 80lb/h injectors @ 19psi he made 397 rwkw on a hub pack dyno
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
