I've had a sudden decrease in fuel economy, the only thing that has been tampered with recently is I removed my pod filter and cleaned it using k&n cleaning kit. I followed the instructions and am pretty certain I didn't over oil the filter before reinstalling, is there something I may have effected that could cause an increase in fuel use? Or is it simply most likely due to the ridiculously hot weather.
Cheers for any input
https://www.sau.com.au/forums/topic/352903-sudden-drop-in-fuel-economy/
Your pod filter is atached to the AFM it's like a black pipe with an square housing with a sticker on the side ,on the side where the filter is atached is a metal grill an around the middle you have the sensor itself CRC contact cleaner is basicaly hysopropilic alcohol in a spray can,you spray it on the sensor and it gets rid of dirt and grease/oil that deposited on it,you just need to spray it do not rub/brush with anything otherwise you may damage the sensor.
  • Like 1
