Hey mate, this is on carsales atm, might have to get your mate to try and work out a deal
http://www.carsales.com.au/all-cars/private/details.aspx?R=8866850&YearFromShort=1639&__Qpb=true&Cr=0&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&keywords=&YearToShort=1676&__N=1216 1246 1247 1252 1282 4294963593 4294963846 1639 1676&silo=1011&seot=1&__Nne=15&trecs=788&__sid=12CFFFFB1B15
https://www.sau.com.au/forums/topic/352931-wtb-r34-gtr/#findComment-5666044
Might be worth getting the vin BNR34003026 checked on that car as it doesn't look like a genuine v spec and non v spec models usually sell for 4 to 5 thousand cheaper than v spec models. Alsp that vin number would suggest its an early 99 model and not a 2000 model. The guys would be able to confirm it on the "vins you want fasted" thread. If it turns out to be a v spec then the rear and front diffusers are missing and it definately has a non v spec speedo installed.
All good negotiating points to try and get it a bit cheaper if that is the one he likes.
cheers.
Edited by thatlbeme
https://www.sau.com.au/forums/topic/352931-wtb-r34-gtr/#findComment-5674128
I've talked to this guy and the price isn't very negotiable.
He's supplied the VIN, I've put it through Nissan FAST and I can confirm it is NOT a vspec.
I don't know why he claims it to be one, it doesn't even have a vspec sticker in the very least.
No front/rear diffuers...etc.
I suspect he got sold it as a vspec and got rolled, so now wants to sell it as one.
It's a 1999 non-vspec model, 2000 models should have black seats not grey.
Oh, and I also pointed out the fact that I put his car through Nissan FAST and suggested that his car is not a vspec, hoping he'd negotiate the price. NOPE! I was still interested in buying a non-vspec car, but he won't budge. Seems overall dodgy to me.
Edited by EVOIV
https://www.sau.com.au/forums/topic/352931-wtb-r34-gtr/#findComment-5677132
