Hey Everyone Just wondering if anyone can help me out i have a 98 Series 2 R33 Skyline and just recently the car started popping and backfiring a bit when I was driving home down the freeway. Before that It wouldn't start after I had sat in the sun on a hot day but I replaced the spark plugs and that seemed to have fixed that as the old ones were black and dirty. So far Im just trying to find out what the problem is with the backfire and It not running right It started to blow a bit of black smoke and i was revving it to keep it running was a bit scared to let it idle as I didn't want it to stop at the lights. Managed to get it home and now I have done the following. Turbo still spools up and make boost cars running 0.5 bar at the moment and has a BOV POD filter FMIC and boost tap.
Pulled off the front mounted Intercooler piping and joiners and cleaned everything and put them all back on a tightened the clamps and checked joiners for splits they all seemed to be ok.
Replaced the spark plugs
Cleaned and checked the coil packs for hairline cracks looks like the factory one am keen to buy Splitfire coils but am going to wait to see if I need new ones to solve the problem.
Cleaned the AAC valve
Cleaned the AFM ( air flow meter ) had Oil from K&N filter all through it so cleaned that and got a new dry pod filter. Just wondering If it need to be hooked up to a diagnostics computer to check for any trouble code on the computer.
Checked vacuum lines for splits but I may have missed one but seems ok
So am thinking maybe fuel pump and filter need to be replaced or something to do with the injectors ? put 98 in the gas tank and a bottle of wynns injector cleaner
maybe AFM needs to be rebuilt or buy a new one ?
also whats the deal with the different spark plug gaps ?
Any help will be much appreciated don't want to buy new parts till I know whats wrong going to take it to the mechanic soon to get checked out just seeing If there is something I can do to fix it first.
cheers
Tom
try a 0.8mm spark plug gap. also make sure your AFM is plugged in properly. failing those, you can open up the AFM using a stanley knife and re-solder the pins, there is a bit of sealant around the square part on the AFM that you can cut to open it up. just make sure you re-seal it.
funnily enough, if your car is backfiring you will actually make more boost.
hhmm.. Symptoms. Car missfiring. Spark plus black and fouled, changing them fixed the problem.
Then I see it has a BOV.
Keep spending your money, spend thousands. I keep repeating myself. ATMO BOVs do this.
They are just going to keep fouling your plugs and making your car fail.
Why do people see the f**king need to put a BOV straight on these things where there is a perfect, NON constant leak one plumbed back and all neat and tidy. Don't say noise, because that just means you're a full on wanker.
i do agree with you but there is a lot of skylines running stock ecu and atmo BOV without any issues
I've got a non-turbo R33 doing a similar that.
It's backfiring, causing loss of power.
Suggestions given by friends: timing chain and injectors.
If my Consult cable would hurry the f**k up and arrive, I'd probably be able to read out the errors but NOOOO dealextreme is taking forever :P
I was under the impression a AFM system must be completely sealed behind the AFM. If there is a air leak to atmo there would be to much fuel entering the system.
Hey thanks for the replies as for the BOV carry on It was already on the car and the car was running fine with that on its an HKS SSQV and I don't have the stock one. The AFM is sealed off it has an intake pipe to the turbo with silicone joiners on both ends then the AFM then an air filter clamped to the AFM. I think It need to have a diagnostics session with the auto sparky to see if any thing pops up on the ecu trouble codes. Kinda is making the same problems as my old 96 WRX did when the airflow meter was on its way out. Do the RB's run a timing chain or cam belt ? Also do you just buy spark plugs gapped to 0.8mm ? cheers Tom
If you retune a car after adding an atmo bov you can get rid of most of the backfiring and stalling, but with the stock tune it will never play nice.
Eg the redtop rb20dets that had no bov, they get crazy reversion and don't backfire or stall.
i know of heaps of cars running atmo BOV's with out over fueling issues, yes sometimes they try to stall but never over fueling issues.
OP see if you can borrow an air flow meter off a mate or on a cruise night etc, this is the best way to diagnose if its the cause
Think I may have found part of the problem was just look around the engine bay and found a small vacuum hose has one split on the end and the other has snapped off now where did it come from its a small 4mm inside diameter hose its black and has a green strip on it any one know what that hose is ?? i found it near the front of the intake plenum.
Had a look around still cant find where the vacuum line came from its black with a faint green stripe down the side of it one end is broken/hard and dry and one end has been over a nipple but has a split on it the bit i have is about 300mm any body know what that hose mite be ? i hope this will fix my problem
where is it? what is it connected to? what side of the motor? picture?
your description is shit.
edit: yes, that is definitely capable of causing the problem you are describing. replace the hose.
Edited by SECURITY
Thats the thing I don't know where I came from is there a type of pressure test to do on the vacuum system ? if so how do you do it ? Ill take a pic of the hose but it could have just been replaced earlier on and some one just left it there ??? ill put a pic up soon cheers
sounds like the fuel reg or the boost guage line.
any vac leak will make it run like shit though, look harder, you'll find it eventually.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
