Hey SA SAUers,
I am still fairly new to this forum, and are getting extremely close to buying one of my dream cars in an R32 GTR. Which brings me to my question.
I am generally looking 1992 to 1994, however i am accepting earlier with a rebuilt motor.
What are the physical differences between 1989 to 1994 GTR's? I have seen some 1993 models with side indicators and some without. Is that all?
Please advise, i will be making my purchase hopefully within 10 days....
Cheers :cheers:
Matty
If the rebuilt motor 32 has had the crank shaft changed to a 33 GTR one or had it sleeved id go for that one. One of the major floors with the 32 GTR motor is the crank design into the oil pump. It has about 5mm of contact and is the first thing that goes. You completely lose oil pressure and you need to pull the motor to replace the pump. They fixed the design with the 33 GTR crank. Hope that helps with ya decision
Mid 93' onwards have a different clutch system to the earlier GT-R's.
89' GT-R don't have badging on them apart from the 'R' from memory.
The side indicators are simply compliance - so if it has them its a newer import as previous years it wasn't a requirment back then... ummmmm... as per above the crank collars are different. The center dash console bit that goes around the CD player etc in 89's and 90's from memory is a black colour compared to the later models with the rough look finish plastic similar to rest of the dash...
Think thats about it?
these are the following mods to one i am looking at with a fresh rebuilt motor with 240awkw
Nismo Twin Plate Clutch, Nismo Engine Mounts, Nismo Baffled Sump, New Drive Shafts, N1 Oil Pump, R33 Snout Crank, Recon Head, 600cc Injectors
What the hell is a snout crank? Is that what you were talking about trick? What do you think about the mods?
Matty, sounds like that GTR has the 33 GTR crank in it. The snout they mention is the end that fits into the oil pump. So yeah that motor sounds good. Now ya just need to decide which to buy. If it were me id lean towards the rebuilt motor one. Its all done for ya, just depends on the rest of the car I guess
The rest looks awesome mate, (dont wanna give to much away unless some bastard gets in before me!!) i think its a goer.
The only question i have now is the N1 oil pump. Our mate above thinks they are bollocks, but im not one for thrashing my car at all. (in saying that though, i do love the sound of a RB26 at 8000rpm!!:rofl: )
Will have to discuss this further.
Thanks for all your help, i literally know nothing about cars. I can put more oil and water in and change the tyres but thats as far as my mechanic mind goes.
Cheers mate
N1 oil pump at 8000rpm = lol bearings.
Seriously dude, just search on these forums for the N1 oil pump arguements and you can make up your own mind :)
Edit: here. Read this: http://www.skylinesaustralia.com/forums/topic/283867-n1-oil-pump-epic-fail/page__hl__n1+oil+pump
Edited by CRoNic...
No worries CRoNic,
Lots of pros and cons suggested on that forum. Some say they last for ages and some say they die within 1000km...
I will have to make a decision once the purchase is done.
How much are we talking for an upgraded oil pump? Is it how much you push your car or they just die for no apparent reason?? The forum again states this but i dont quite understand why...
Endless pools of money GTRs aren't they? I dont care.... GTR..(like HSV)... I Just Want One!!!
At the end of the day matty if you buy the rebuilt GTR and IF the N1 pump goes (which i dont think will happen) you still have allot of mods done to this car. on the other hand WHEN the std oil pump goes on the other GTR's you still have to pull the engine appart to fix the problem. N1 oil pumps generally will be fine in a 32, more so compared against the std so really its a better call to buy the rebuilt GTR, in my opinion anyway.
hope the info helps matty
This is incorrect. N1 pumps have bigger gears than the standard pumps, however due to this there is less clearance at the lowest point of the gear cutout. Standard pumps won't pump as much, nor at the same pressure as the N1 or aftermarket pumps, however they won't die as easily as an N1 pump.
Check this pic out
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=215653
Notice the thickness on the outer section where the tooth slides into? On the first two its rather thick, 4-5mm it looks like. Check out the thickness of the outer edge of the N1 pump - its thin as, 2mm or something.
When the revs go over 8000, that is what breaks. You won't have this problem on a Jun, HKS, Tomei, Nitto or even Nismo pumps as they weren't manufactured with such a small amount of metal holding those teeth in..
If I was you, buy the built engine with the n1 pump, and when finances permit it, then take the engine out and replace that pump with a Nitto (or brand of your choice).
In either case, just keep the revs under 7500 to be safe and if you want to take it to a track, then change the pump
-D
cant find pics but the key difference that all true buyers should be looking at is the real early models have a ugly circle a/c button while the newer 1s have a true 80s style square shape :D
actually having pretty hard time finding the circle a/c button on the net musta been pretty rare
Edited by Inline 6
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
