Need to get rid of some of the crap i have lying around cause i need the room.
-GTST Passenger seat. Excellent condition (not the cloth trim the nicer velour GTR style)
-GTST front guards (black in good condition, minor scratches and pin dents)
-Rear spoiler - FREE if someone wants it, its the 3 pillar type
-Fog lights for the GTST in perfect working order SOLD
-Bootlid. Holes welded but some rust needs to be removed etc SOLD
Make an offer on any of em... or they will be thrown out.
[email protected]
https://www.sau.com.au/forums/topic/35326-r32-bits-and-peices-melb/
will take a pic tomorow and post it up for u dude... be better cause then if u wanted to u could keep ur other lid with a different spoiler on it for if u do track or drag work etc
heheh, u read my mind matey :D thanks.. speak soon :D
mark
heres the pics... dirty as all hell lol
the rust is just surface rust and will be easy to get fixed... the rest of it is very straight.
anyone want the guards? they can have em for $40 each cause they were scratched up when we moved house.... which is still bloody cheap for genuine nissan guards... might come in handy for all u drifters :P
Please Tell me you havent given the gaurds away for nothing :)
Im in desperate need of them if you are talking about the gaurds that sit over the front wheels. If you have given them away i am willing to buy the passenger side front gaurd of the guy that bought them. This is farely urgent so whoever has them could you please PM me or i prefer you send me an email at [email protected]
Thanks
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
