after inspecting my pvc valve to make sure it was operating properly, i noticed that the rubber seal on the rocker cover had hardened, and actualy broken off into the rocker cover, thank god i managed to get it out through the pvc hold with a hook.
anyway, where can i buy these seals? my pvc valve has half a seal and currently being cable tied in place lol
any ideas?
https://www.sau.com.au/forums/topic/353380-pvc-valve-seal-broken/
Yes,the same thing happened to me but mine fell inside the rocker cover so i had to pull it off to get it out! Go to a Nissan dealer, they can supply one for about $20. A bit steep ,i know, but what else can you do?
I got my car back from the tuner after an injector install and found mine hanging inside the rocker cover. Next day to Nissan for the part and $20 later all sweet.
Genuine is genuine guys, I know mine lasted 18 years, for $20 its a good deal.
Think the one I got was for AU/BA but in saying that am pretty damn sure they're all the same...
Have you actually tried fitting it or is it obviously WAY too big?
I am in Cranbourne, near you & I just went to the local Repco to see if they had a listing for R33s. They didn't but I knew some of the guys through work so he went searching with mine as a sample & came back with a Falcon item. Worked a treat!
  • Nope 1
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
