  • Replies 224
OK Everyone, how's this sound:
1. All southside/GC people meet at Springwood crazy clarks at 7:30pm for departure at 8pm sharp
2. Cruise up to New Shell just north of the Gateway bridge on the highway, meet all you brissie ppl there say 8:30pm?
Havent quite firgured out where to go after that, but then again, I'm just making this up as I go alone, with some help from others, strutto and hopefully you........
roma is not gonna be big enough to accommodate all of us... there will be many other cars as well and not to forget the fact that the cops have increased their patrol of the area. Milton Maccas is a no-go as well. i reckon that Ska's suggestion is probably the best unless there's a better place to meet in Brisbane.
where is the New Shell anyway?
ok... so its settled.
Brisbane ppl - meet at Milton Maccas at 7.30pm and we leave at 7.45pm sharp. I will tell Yoparata to meet at 7.15pm cos he's always 20 mins late (got the hint yet, Aaron? :P)
cruise up to the New Shell, meet up with the rest of the group, have a chat and decide what to do from there.
onz?
glenn
I will be up in brisbane on thurs nite (in my flat-mate's gti-r) and will be meeting with some redlineau people, most probably at albion maccas, but its not too far from this new shell. I will try and twist his arm to go for a quick run out there (if you dont mind a jnr zilla about :S )
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
