  • Replies 224
SHIT, I hope I didn't chip anyones paint... :D I sincerly apoligise if I did...
Mmmmm Donuts... :D
John's car is awesome through those tunnels though...
I have pics but I'm unsure of the quality ATM... Give me a bit and I'll post em up...
Once again guys... and gals... a great turnout! Thanks for making the effort everyone.
Lovin your work! :D
Yeah guys cheers, had a good time, ill stress less when the car is finished and things are less visible, my car through tunnels??? huh? what? i didnt hear you.... :D
I was gonna go to that estate but they left before me and i couldnt find them, drove around for a bit then went to a mates place to go 4wd'ing then went home.
No I think that it would have been fine if people had just thought for a second, like strutto, he made sure he was just on right angles/facing you before he started to dance around, others wanted to flex thier musclues too and RA_R33 WOW awesome just gotta remember the people behind you :D
Was all up a great night, thanks to all who came, cant wait for next week :D
More good luck than thought to be honest... I didn't really want to slam into any ones car so I got out of the way...
I'm a bad man...
just got home...
stayed on with Charly after Strutto, Ska and Zoix left. Yoparata joined us shortly after his little rendezvous in Sunnybank. So did Owned.
then the cops came... pulled up RIGHT infront of us and asked ONLY Yoparata and Charly for their licenses and registration... anywayz... Yoparata smooth-talked their way and the cops just got back inside their car and went hounding after some 18s yr old in a 180sx.
good nite all :D woot !!
I haven't actually looked at my car in the daylight yet. But I shall be once I leave to go to work.
Just remember for future events guys, that if you want to be silly in a carpark full of rocks, please get out of the way of all the cars... It's common sense!
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
