Hey everyone,
Currently importing a R34 over from JP... I previously owned a S2 Stagea...
I couldn't help but notice that 34's don't have gas struts? Where as the Stagea did.
I can only assume that Stagea's and R34s would be able to share the same Strut. Can anyone confirm?
Cheers
https://www.sau.com.au/forums/topic/353483-er34-gtt-hood-gas-struts/
No skyline has gas struts on the bonnet.
You can get aftermarket ones that fit the GTR models, but not the GTST/GTT models. Having said that, some people have fitted them and I have looked into this myself.
The main problem seems to be the mounting position on the guards, hence why the GTR ones don't fit the GTST/GTT.
Yeah Ive been looking around... All good. Bonnet rod/stick/thing it is LOL
you can most certainly fit them yourself, just takes a little bit of work. just get some using the same part number as what the cefiro uses (can get munroe brand ones - i think - from autobarn, but they will cost you about $80 from memory). i was going to do it for the missus pulsar but was too lazy.
