a couple of us have 'been' on tassie cruise club cruise's, they usually aren't huge.
i know for a fact that hobart cruise club has huge cruises and its real organised.
elysium and platinum usually have decent cruises to devonport, few out to undisclosed locations (cops shut them down).
https://www.sau.com.au/forums/topic/35353-clubs/#findComment-707067
Hobart Cruise club are very organised, They often have a large turnout as well, they are all keen for a cruise any time ...
They have a range of cars as well, so you won't feel bad if you don't have a Top notch car.. There are some Bombs lol...
They are actually cruisin this weekend
https://www.sau.com.au/forums/topic/35353-clubs/#findComment-707415
Hobart cruise club should be called Hobart Commodore Club...nuff said. I was a member once, however found quickly that its got about as many sensible, decent members who can drive, and don't have illegal shitboxes, on each cruise as a tiny little club would - the numbers are just beefed up by knuckledragging morons.
If you hear where they're cruising to, tell us, I'd live to know which areas to avoid...
I think cruise clubs are a liability.
https://www.sau.com.au/forums/topic/35353-clubs/#findComment-707541
Mate, its just my opinion, go on the cruise if you want since theres no other game in town, but, I wouldn't go near them with a 60ft Idiot Avoidance Pole....
have you got anything to base your comments on?
'hobart commodore club'??? you obviously havent bothered counting the amount of commodores in the club. there are about 20, and if you looked on the site you would see there are more than 80 cars with pics on the site, and then there are more that havent had pics put up of them yet. The club has almost 120 paid up members and less than a quarter of them drive commodores. so i dont see why it would ever be called the hobart commodore club.
im not meaning to start a bitch fight with you or any club you are in, im just correcting your ignorance.
thanks.
https://www.sau.com.au/forums/topic/35353-clubs/#findComment-717379
Doesn't raise the average intelligence level of the members. I was a member for a while myself, saw the stupid behaviour, and left.
I don't want to be associated with dickheads and with 120 members (despite the best efforts of the hard working organisers), theres bound to be more than a few. Since it only takes one, well thats bad odds to me.
Hats off to them for doing something though! And the supercruise weekend was one of the first times I've been able to drive through town in the evening without the "blockie bandits" screaming around making dicks of themselves, so hats off to them for attracting the dickheads away, like mosquitoes to a flame..
https://www.sau.com.au/forums/topic/35353-clubs/#findComment-718192
I cruised up with them from hobart to Launceston... (even though it cost $85 in fuel to get there and back) and I never saw any stupid behaviour...
Although i did see some Not so cruise type cars...
There wasn't much group action, the whole group tended to split a fair bit, I think some more activities would have been good... it wasn't much of a cruise with all the cars seperated.
But I wasn't on the entire trip.. so I can't say anything good or bad about it.. Apart from there was a coulpe of nice cars....
I only knew a couple of people... damo (r32 gtr), Collin (blue wrx) and Mike (Lancer GSR)...
Apparently they had complaints made about them... I really have no idea why...
https://www.sau.com.au/forums/topic/35353-clubs/#findComment-718280
cruises are ok, can be heaps of fun, but they can also be dangerous, if anyone can remeber the cruise back from andy's bakery in westbury. that could have ended in disaster easily.
i would personally rather track days, hill climbs, drift comps and drags
https://www.sau.com.au/forums/topic/35353-clubs/#findComment-718337
im not going to argue with you, but you are wrong.
goodbye :wavey:
https://www.sau.com.au/forums/topic/35353-clubs/#findComment-718451
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
