Hey guys,
Got another set of wheels for sale, taken off one of the cars I recently purchased.
They are quite rare in this size and cost a sh!tload brand new. Wheels are silver with polished lip.
Will post pics up tomorrow night but from memory 2 of the rims have slight gutter rash.
Tyres were quite worn will check tomorrow but I'm sure there was at least 50% tread left on them. Good for atleast a couple (if not more) track days.
They are 18x10 with a +20 offset, suitable for R33 and R34 GT-R's. May fit R32 GT-R's but will need some sort of guard mods (lipping) and some decent negative camber.
Located in Narre Warren North (VIC) but will ship interstate at buyer's expense.
PRICE: $3200 ono
Pics to come.....
Cheers,
Jack
OK, here are some pics.
Pics of each individual wheel...
And some of the tyres...
As the pics above show there are a few marks on 2 of the rims, and the tyres have a bit of life still left in them....
PM or reply if interested, price is negotiable...
Cheers,
Jack
+1
These will fit in 32 GTR, maybe narrower tyres though.
Best of luck in sale Jack, I miss these.
+1
Yeah I'd say maybe a 245 or 265 wide tyre might do the trick.
oh geez.. jack, why do you always sell awesome rims that wont fit my evo? :(
Buy a GT-R!!! :P
Still for sale......
^^ Nah, I bought a set of CR KAI 18x9.5 +20, had 245/40/18 all around, and it rubs badly. took it off after 8days and sold it for dirt cheap price lol.
Have you got coilovers in your evo? Bit of camber, shaving the rear bar and the bolts for the rear bar in the wheel arch and they fit, although a +20 i don't know if it would fit haha. Plenty of evo's running 18x 9.5 though. I'll be running 18 x 9 on mine
^^ yep, cusco zero 2R, -2ish camber, still not good.
didnt shave the rear bar and relocate the bolts though..
anyway sorry for hijacking your thread, Jack. wondering what's the next rims you'll put on for sale.. :)
Edited by gerz
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
