Drag and street dont go well together. Usually whats awsome on the street is dissapointing on the strip.
Not to mention we all live in the land of defects now. My advise would be to build a streetable car, that looks stock, but blows away 97% of the competition.
The recipe is a very well trodden and proven one.
*HKS 2530's with HKS actuators
*HKS Split dump pipes
*Full 3inch (minimum) exhaust. dB requirements are different from state to state, but around 90dB is the limit, so a couple of mufflers or a silencer is advisable.
*Apexi Power Fc
*Boost controller (HKS, Blits Apexi etc)
*minimum 660cc injectors
*larger Bosch in-tank fuel pump
*Cam Gears (Os Giken, Tomei, JUN)
*Minimum twin plate clutch
*Either Twin Pod set-up or higher flow air filter. But I would recommend still using standar air box.
*Nismo or Z32 Air Flow Metres
*upgraded brake pads
You dont really need another intercooler. Standard GTR will flow ok. Dont really need cams either, but HKS step 1 are a direct bolt in option, so they are pretty good.
Thats what is a great street car, and with tuning and installation 15-20k is around the right figure (if you are buying brand new components)
This will net you around 320rwkw.
Any more and it internal time, bigger everything (turbo, injectors, clutch, gearbox etc) add another 20-30k (including labour, tuning etc)
https://www.sau.com.au/forums/topic/35358-gtr-wat-to-do/#findComment-709105
*Apexi Power Fc
I agree with everything except you definately need an intercooler min 100mm. Air flow meters are debateable, maybe a set of coils.
https://www.sau.com.au/forums/topic/35358-gtr-wat-to-do/#findComment-709473
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
