Drag and street dont go well together. Usually whats awsome on the street is dissapointing on the strip.
Not to mention we all live in the land of defects now. My advise would be to build a streetable car, that looks stock, but blows away 97% of the competition.
The recipe is a very well trodden and proven one.
*HKS 2530's with HKS actuators
*HKS Split dump pipes
*Full 3inch (minimum) exhaust. dB requirements are different from state to state, but around 90dB is the limit, so a couple of mufflers or a silencer is advisable.
*Apexi Power Fc
*Boost controller (HKS, Blits Apexi etc)
*minimum 660cc injectors
*larger Bosch in-tank fuel pump
*Cam Gears (Os Giken, Tomei, JUN)
*Minimum twin plate clutch
*Either Twin Pod set-up or higher flow air filter. But I would recommend still using standar air box.
*Nismo or Z32 Air Flow Metres
*upgraded brake pads
You dont really need another intercooler. Standard GTR will flow ok. Dont really need cams either, but HKS step 1 are a direct bolt in option, so they are pretty good.
Thats what is a great street car, and with tuning and installation 15-20k is around the right figure (if you are buying brand new components)
This will net you around 320rwkw.
Any more and it internal time, bigger everything (turbo, injectors, clutch, gearbox etc) add another 20-30k (including labour, tuning etc)
https://www.sau.com.au/forums/topic/35358-gtr-wat-to-do/#findComment-709105
*Apexi Power Fc
I agree with everything except you definately need an intercooler min 100mm. Air flow meters are debateable, maybe a set of coils.
https://www.sau.com.au/forums/topic/35358-gtr-wat-to-do/#findComment-709473
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
