don't know the rims, almost look like an aftermarket version of BMW m6 rims with dish.
but what i want to know is WTF is this boat in the background!? hydrofoil1!!?
http://img138.imageshack.us/img138/9138/p19633151.jpg
https://www.sau.com.au/forums/topic/353584-m35/#findComment-5665842
http://img138.images...8/p19633151.jpg
Yep sure is...
Most of the cars in this blog looks like ass...lol the whole rear wheel with huge neg camber is just...:sick:
https://www.sau.com.au/forums/topic/353584-m35/#findComment-5665853
Yep sure is...
the camber on this car is bs u only need camber for racing etc , i was talkn about wheels but its ok if found wheels now that are similar that i wan t
wolf VVS084
https://www.sau.com.au/forums/topic/353584-m35/#findComment-5665868
i got moneys , is there a air bag kir for stageas out there ?
Import Monster.
While you're at it, better buy some sick bags... That thing looks bloody awful and airbags will make you seasick.
Edited by Daleo
https://www.sau.com.au/forums/topic/353584-m35/#findComment-5665888
sarcasm tags are italics bro, l2useforums :P
airbags would be awesome for track days
i'm not an MSN whore.. I don't get all these abbreviations like affaick and poo poo or whatever they are.
My sarcasm is so sarcastic, people believe it hahaha :nyaanyaa:
Edited by AaronNM35
https://www.sau.com.au/forums/topic/353584-m35/#findComment-5665905
it gets worse...and this is actually riding on coilovers (or 'static' as they say). there is a vid of it driving on the page
http://www.stancenation.com/page/9/
Edited by SMOKEYC34
https://www.sau.com.au/forums/topic/353584-m35/#findComment-5665970
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
