A little while ago I was punting around a corner I know very well. Sometimes, when I'm feeling frisky, I hit it hard in 1st (tiptronic) and can get a smooth drift til traction catches up with me. This was with 235/45ZR17 tyres.
Now tonight was different because it was the first time I'd hit that corner since I got the 225/40ZR18 tyres on.
I had actually decided to go quickly but within traction around the corner and changed into 2nd gear before I got to the apex so I was barely on boost but with next to no warning the back let go in the same fashion as it would have if I'd meant to drift it. I didn't lose it, just grabbed it back the way I usually would but I was surprised.
Now my question is; Is it just my imagination or do lower profile tyres by their nature give less warning at the limit of traction or is it possible that the width was an issue?
As a side; Can anyone translate the full codes I posted above?
PS. I felt the slide was smoother with these tyres.
235/45/R17:
235=tyre width in mm;
45=thickness of sideway as a % of the trye width (ie: 45% of the tyre width.);
R17=17" tyre, Radials.
Yes a smaller profile tyre will have less flex and be more responsive. Having less width will also have less traction. Different Brands/models will have different road holding characteristics, due to the different compounds. Finally whether and foreign residue on the road will also play a major part on road handling.
It also depends on the compound of the tyre.
Being different brand (I presume) they will handle differently.
Some tyres give you heaps of warning before they let go, some stick really well right to the end and then let go really fast.
J
OK Sarpi, last 1 first.
225/40ZR18 means a tyre 225mm across the tread, 40 means the height of the tyre from the rim to the tread is 40% of 225mm (=90mm in this case). Z is the speed rating (= lots, not sure exactly but over 230), R is radial (they all are these days) and 18 is the size of the rim they fit on.
So the main thing about your new tyres is they are 1 cm narrower and on 1inch bigger rims.
As for "feel"....
firstly, are they the same brand and type of tyres? that's the main factor, there is a huge range in feel when tyres let go....generally the worse the tyres the more warning you get...with top ® tyres they basically stick like mad until they very suddenly let go.
If they are the same type of tyres you might be noticing the difference in sidewall height....but both 17s and 18s are big wheels which will have minimal sidewall flex.
Also make sure your tyre pressures are right for the tyres, normally up to 45 hot is about right.
Being a lower profile tyre, the sidewall is narrower. Therefore there is less flex available in the sidewall to absorb distortions. The tyre presumably puts a smaller footprint on the road. So the limit of adhesion (forwards + sideways) is going to be different (presumably less) with the 225/40ZR18 than with the 235/45ZR17.
If it is a little bumpy, you will find that there will be a tendency toward 'sudden' traction loss on hard cornering due to the reduced sidewall flex.
This is why I went from 235 30 ZR17 to 255 40 ZR17 for daily driving
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
