Hey guys,
Ready to order pistons for an rb25/30 build i'm doing. Purchasing JE customs for the combo. Question is what compression do we want.... Want to run a gt35/40 sized turbo at around 18 - 20 psi to make around the 450hp mark at the wheels. Any one with a similar combo making similar power thats been running good for a period of time?
Looking to upgrade the camshafts also. What make of cam are you guys running in your cars?
Planning to use acl race series main and big end bearings, anyone heard anything bad about them or have a make that you would recommend?
Kind regards,
Tas
https://www.sau.com.au/forums/topic/353651-rb2530-build/
I decided to go 9.5:1 (Custom CP's) instead of the standard 8.5:1 as I plan on using high octane fuel at all times and possibly E85 down the road. Even if I have to back off the timing a little it will still help having a little extra compression.
As far as the cams go, I have gone with Tomei Poncams and matched them with Tomei Valve Springs. Depends how much the car is used for everyday stuff where you want to eliminate noise and smooth drivability to some point.
I used ACL bearings all round and wouldn't even look at anything else.
https://www.sau.com.au/forums/topic/353651-rb2530-build/#findComment-5668115
i see, we are thinking on using the 8.5:1 and the car will probably only ever run on 98.... i have performance springs (brand name) and am yet to decide on cams the car will be driven almost daily.. and i am gonna go with the ACL bearings also which tomei pon cams do you have ?
https://www.sau.com.au/forums/topic/353651-rb2530-build/#findComment-5668179
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
