Ok so, One of the cars I currently have is a R34 GT (aka non turbo) and it's also tiptronic (boo - But nice for "friendly" driving) ... I'm considering purchasing a Rb26dett from a R32gtr or maybe a r33gtr ... it would come with tranny, turbos engine and all major bits.. (Happy to transplant the transmission into my R34 to make it manual)
My question is - Is it possible to swap the engine into my R34 without INSANE costing? ... what would be involved? ... can anyone think of any parts that I might need? ... has anyone done it before that can give insight? .... and finally, can anybody recommend anywhere in WA that is capable of doing it without making a huge debacle of it. (Please don't recommend Xspeed.)?
Cheers :)
https://www.sau.com.au/forums/topic/353713-rb26dett-into-a-r34-gt/
How much cash do you have?
Because i cannot see you getting away with less than 8-10k in all honesty.
As to get it legal you'll need to change the brakes over, which means going 5-stud also as its too time consuming with 4-stud
Then there are issues with the single spinner diff - gearbox isnt a straight swap
etc etc.
Better off just selling and buying a GT-T with a RB25NEO
Will work out cheaper and you can still get 260-280rwkw safely with minor mods.
IMO putting an aged 26 in, is going backwards.
Also not sure about WA laws - but over here you cannot put an OLDER motor into a NEWER chassis.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
