  • Replies 46
Mitsubishi Magna Solara a few years ago.
Mazda CX-7 or some variant of soccer mum car (not a Territory) a couple of days ago. Only giveaway was their uniforms and the fact they were tailing me for a while.
Undercover motorbike - these will really trick you.
img]http://www.muamat.com/adpics/4bf74fb375c913af78812e58c.jpeg[/img]
One of these.
One of these.
And a KE70
I think they pulled the last two from lockups or something.
Also heard of unmarked FPVs and HSVs trying to gee up drivers.
i saw a suzuki swift.. wasnt undercover.. had stickers lights and all.
I've seen that one too. A year or 2 ago, a Suzuki dealership gave the Dandenong Police Department a Swift as a gift of appreciation.
Yes to motorbikes being tricky. Especially undercover ones.
Also seen a VS station wagon undercover.
I've seen the opposite.
fake cops
as many of us know there are a few places along the Hume where cops are know to lurk.
I went past one with a life size Cardboard police motocycle in one..
very well done and slowed lots of ppl down too, (well till you went past and saw it was 1cm thick.)
fake cops
haha was that the one just after cragieburn?
i saw that and thought it was pretty cleaver lol :P
Mazda 3 MPS - serviced it at work in keilor area
Mazda 6 MPS - serviced it at work in keilor area
Audi A3 2.0T - serviced it at work in Brighton area
Cardboard Sign on hume got me lol
Heading up to Sydney tomorrow. Won't get me this time unless they are playing boy who cried wolf and real one sitting there.
I think it would be funny if you were driving an everyday beat around and ran into the cardboard cop.
....Hopefully it's still cardboard 2nd time round....
EDIT: I thought Evo cops were only in NZ?
Edited by TyresBro
Ford Territory Turbo.
Parked out the front of where I work.
Mate the Territorys are everywhere lol.
There was actually one time on the M1 freeway from north heading to SE suburbs. A policeman was taking speeds of drivers right at the merging lanes but on the zebra zone. Found that quite odd.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
