Hey guys, Just an EOI at the moment, im looking at buying a new set of wheels or trade these for something else... show me what you have. Im after 5 or 6 spoke 17 inch or 18 inch jap wheels or jap 'style' wheels. No chromies.
They are Stamford wheels 'Imagine'
Fronts are 19x8.5 with 225/30/19 Kumho ecsta ku31 tires - Basically brand new, just put these on last week
Rears are 19x9.5 with 265/35/19 Goldenbridge tires (forgot code name) - about 6 months old. still lots of tread.
I paid $1500 for these brand new, i'd be happy to let them go for $950 or trade of something i like..
Sorry for blurry pics....
Thanks
Edited by Aleckr33
https://www.sau.com.au/forums/topic/354043-eoi-ssw-imagine-19x95-19x85-wheels/
Hey dude, I'm lookin to swap my wheels (In my avatar pic)
Enkei Circulars in white- 18x8 225 tyres all round, not sure of Offset, I'd have to check the wheels, prob +35
Hey mate,
Yeah im after something a little more of a staggered look at the back like 9.5 wide.. Nice wheels though.
Interested in swaps guys, not really wanting to sell these..
Edited by Aleckr33
  • 6 months later...
Bump
Make an offer!
No buckles or paint fading, a few gutter rashes here and there but nothing serious that stands out.
Tires in good condition, plenty of tread.
Will send interstate at your expense.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
