wheres a good place to get a nistune? im surprised no one mentioned injectors..or is that pointless untill hunting done more power in the future?
sorry guys i only asked for a stupid number like 5 mods cause of budget limits :(
p.s if i were to set my boost at 10psi(stock turbo/r34 gtt smic) would a boost T do the job?
thanks for the feed back so far guys
Injectors would be like number 6, along with fuel pump. The others mentioned are the mods to start with because without those injectors are pointless. Why would you need them without the extra power/need for fuel?Yes a Boost T would do fine.Just do some searching on this forum, you'll find endless threads about reputable workshops, what mods to do first, what gains to expect, info about ECU's etc.
1. put a built RB30 bottom end on
2. build head/cams
3. put a correctly sized turbo on
4. injectors
5. OIL
Thats on the mota, then the ECU, then the fueling, then the tune, then the drivetrain, then the suspension, then the brakes, then the tyres, then the cooling (i/c oil cai)
And then, and then, and then
Welcome my friend.
iv come to realise that the mods never end do they haha
yeah i might leave the injectors later once im keen on more power but i might just boost to 10psi and get some new spark plugs
once iv boosted should i get a tune done or not really needed??
ok, cheapest decent power available: :)
1: gcg highflowed turbo - 2nd hand - $1000
2: turbo back exhaust - jjr or similar - $1000
3: turbotech (not turbo smart) boost tee - $50
4: china spec fmic & piping kit - $300
5: nistune - $800
6: clutch - exedy single plate button $500
7: diff - welded - $100
ok, so for $3750 or thereabouts you can have ~ 230rwkw and a fun car to drive. add coilovers for around 5 grand that's pretty sweet.
injectors, z32 afm and fuel pump could be added to this later on for around $1500 and you will have ~260rwkw
  • Like 1
For the fully sick individuals:
1) paint brake calipers red (+25rwkw)
2) flower stickers on rear window (+5rwkw per sticker)
3) fake turbo noise clip-on for exhaust (+50rwkw)
4) Neons (+35 rwkw per item)
5) 22" China spec chrome dinner plate rims (+90rwkw per wheel)
Or
Sell the car & buy a Hyundai Excel, do the above mods to it for the instant over 9000kw
For the normal people:
1) turbo back exhaust + high flow CAT
2) high flow panel filter + stock air box or POD with enclosure
3) Intercooler upgrade
4) Boost controller (manual or electronic)
5) Some sort of engine management + tune
Edited by Mayuri Krab
5: nistune - $800
this sounds goood, since im on a cheapish budget...but i might get a jap intercooler since iv heard alot of people complain with the chinese ones.
quick question whats the pros and cons of getting my cat high flowed??
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
