Make : Nissan
Model : 1990 R32 Gts-t, 4 Door
Milage : 158,000km
Transmission: Manual
Colour : Sky Blue
Complied? Yes
RWC supplied? yes
Currently registered? Yes
Price: $12,500
Contact: Pm me
- 17" ROH Rims
- Trust Exhaust System w/ dump pipe
- Apexi Pod Filter
- Greddy Front Mount Intercooler
- Cusco Front & Rear Strut bars
- Blitz Turbo Timer
- GTR steering wheel
- GTR front bar, Type M side & rear skirts
- Boost gauge
- Pioneer CD Player (Jap)
- Pioneer front speakers 4" x 6" and 6.5" rear speakers
- Alarm system
Item: Pair of Sparco Sprint seats.
Condition: Good but missing the plastic inserts for the passenger seat and the lower driver seat ones (see pics) but the holes are covered.
Price: Make an offer/swap for a set of 32 gtr seats. (Willing to fix value with cash depending on the condition of the gtr seats.)
No longer for sale! I've decided to keep them. Could a mod delete this post the "for sale" post please?
RB20DET stock turbo and manifold
Condition: Good
Notes: Been on this engine the whole time its been in my car (nearly 3 years now). Been running 13psi easily and safely for the last 12 - 18 months. Last time i checked there was no shaft play, but once its detached from the motor i'll double check its condition
Reason for sale: Complete upgrade
Price: $200 ono (as its got the manifold too)
Contact: Via PM
555cc sard/denso injectors $550 still in great condition been clean and flowed before i bought em, was going to chuck em in the car but my mrs going to be driving the r32.4 for now so gta sell the upgrades. can contact me on -0422319720
hey,
i have a 3inch front dump pipe (advance brand?) SOLD
FET turbo timer $10
RB20det gear box w/clutch(stock r33). was very smooth in my car no noises or anything.. $600.
also got a datsun blubird, needs new tyre, change of rego papers, it does run and runs well.. 5speed manual, 2ltr.
$500...
cheers
hey all
got a couple of items tryin to get rid of all i want is wat i paid for them
pm me or text or call me on 0422 598 323
SR20 radiator, shroud and fan $50 for lot
R33 M-spec sideskirts $70
cheers
chris
sideskirts SOLD cheers marko
Z32 AFM with plug, $230. still in excellent condition. contact Kiet -0422319720
sold sold soldddddddd
Got to clear a few things here cause shed is full! Not too sure on prices so I'll have some guesses but feel free to make me an offer. I live up south way.
GTR Spoiler in white off my GTST, few chips on it. $50
RB20 coils in a splitfire box. Uppon pulling them out I wasn't miss firing $50
Davies Craig 14" thermo. Kept car cool fine over about a year but now I'm just using RB25 stock fan on new motor. $150 with thermo switch (retailed at over 350)
White Dials from the group buy. Got black gauges so I stayed black. $50
Stock r32 gtst exhaust with a trendy muffler welded on. Welded on pretty dodge but no leaks. $150 (muffler alone costs more)
Still got these mags kicking around the shed. Unsure of offset, needed front spacers. No rash, good cond will take offers around $300 this weekend!
I also have some RB20 motor bits which will be left over from conversion, stock GTST swaybars and some Holden 253 parts.
Just PM me and offer if interested in anything!
Rims and spoiler sold!
For Sale
Rb20DET, 25DE and RB26DETT Splifire coilpacks
Used for about 6 moths over less than 10,000 km and in perfect condition. Selling due to RB25 conversion.
Looking at around $400 ONO so PM me if keen!
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
