mines triple flow cam cover baffle plates for rb 26 motor $275 BRAND NEW
stop blow by in the head, reduces the need for a catch can
brand new http://www.mines-wave.com/english/CATALOG/...AFFLE_PLATE.htm
"In case of the Nissan RB26 engine, the engine oil sent to the cylinder head remains inside the head without moving to the engine block due to its construction structure. Such oil remained inside the cylinder head will be discharged out together with the blow by gas since the oil will change its location according to the vehicle acceleration/slow-down & cornering. The Triple Flow Cam Cover Baffle Plate from Mine's has 3-layer structure, always maintains the gas passage. In addition, the gas/oil separator slows down the blow by gas flow and reduces the quantity of the discharged oil."
accidently ordered 2 pairs
$275
can meet in town weekdays for pickup
posted here, if any interest before posting in SAU classifieds
PM if interested
regards Jason
Greddy Turbo Timer with r32 harness - pretty much brand new $120
3 Drift Gauges (boost, water temp, oil pressure) $40 each
K&N pod filter - $20
how big are the boost gauges?
52mm or 60mm?
boost gauge is that in psi or bar?
Do you have the sandwhich plate for it?
PM me please
FOR SALE:
1992 Kawasaki ZXR750
Good condition, runs great
Has rebuilt gearbox and rebuilt carbs
Quick sale ... bargain $2000
Road registered or good for track bike
2003 GSXR600 Race/Track Bike
This has been my race bike for over a year. Selling due to downgrading to 250cc grade.
23,000kms engine. Engine is A1
2 sets of race glass
Tyre warmers and race stands
Full Leo Vince race system, Power Commander IIIr piggy back ecu
Showa USD fork conversion
Frame has been worked on and approved by Adrill Engineering
Raced for 3/4 of one season before I broke my shoulder. Only track days since.
Bargain $5,000 ono
Now the biggie! ...
2004 MV Agusta Brutale F4
Italian style and engineering with a 4cyl engine designed and built by Ferrari (hence the "F4")
Pure porn with carbon fibre parts (over $2,000), Ohlins adjustable shock ($2K)
Bike retails for $23K new
Fully rebuilt and customised with under 2K on the clock
$18,000 ... no dreamers ... no test rides.
PM for more info and pics
