Reclinable Autotechnica Reclinable Race Seat - Black in colour good condition comes with rail to suit R33 for drivers side
$50 Firm
I'll take it pending picture! No rips or nicks? PM sent.
$50 Firm
If Ruby doesnt take it then i certainly will mate
For sale: Series 4 FC project complete car inc S5 13BT and box
Item Condition: Needs work
Price and price conditions: $2500 ONO
Extra Info: Basically a project I picked up off a guy to continue but I have since had other commitments. The car started life as a series 4 auto NA and now have got all the manual bit inc trans, pedal box and cylinders, a 13B T out of a series 5 and turbo brakes. Body is in ok condition mainly in primer but contains complete interior and spares. Body needs to be completed (no major probs), wiring taken care of and manual gearbox mount fabricated.
Pictures: As per request
Contact Details: PM or SMS 0438885649 for any more details or pics as I know my description is a little brief.
Delivery & Conditions of Delivery: Pickup
Item: RB25DET 3inch dump and front pipe including oxygen sensor
Condition: Used but good
Price: $100.00
Item: Autotechnica driver and passenger reclining seats in black
Condition: Brand new never used
Price: $250.00
Item: RB25DET series II turbo
Condition: Working condition and blows no smoke, only removed for upgrade
Price: $150.00
Contact by PM or 0434 242 324
my BNR32 GTR is up for sale, my tickets are now booked for overseas so i would rather the money to spend over there than have the nissan take up room in the shed for many months. great clean example, the pics i posted on carsales dont do it justice ive gotta get out with a propper camera and get some decent ones!
http://www.carsales.com.au/all-cars/privat...TR&trecs=19
price is 19,500 ONO, im a reasonable man but in no rush to sell it.....
SOLD, bye bye datsun
R34 GTT 4 door FORSALE
Tip-tronic with race shift(chirps the tyres, or flick back to normal)
Delta Fin Front mount
Full Gen Nismo body kit
Full Respray by Pro Finish Custom Painting- Silver Metallic
GTT rims painted 2 shades darker than the car
Apexi pod(std box also will come with the car)
4 layer Silicon Intake pipe
Series 2 cluster and center cluster (displays 134,000, car done 101,000)
Carbon Tint
Alpine spilts all round
Kenwood 7" touch screen
-DVD SATNAV, HDD, USB, MP3, WMA, WAV, AM FM, BLUETOOTH MUSIC, BLUETOOTH HANDS FREE, Relay control for boost select and race shift ability. Cost $3200
Boost increased with stealth control. (looks 100% stock)
Registered in SA (current)
Great condition, come take a look. Not driven anymore.
Matt
0413023669 or pm
$17,000- happy to negotiate a good deal.
PS check out my RB26 Tomei Pro cams 260 10.8 forsale on this tread
Price: $100.00
Price: $250.00
Price: $150.00
Turbo and Dump sold to me ;)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
