OS GIKEN TRIPPLE PLATE CLUTCH, 80% meat left, I need something more soft on my rb20det gearbox this clutch is killing! ill straight swap someone with a their heavy duty clutch with cash my way or straight swap if they put in the heavy duty for me. it'll be idea for rb25> box
Apexi Power FC with hand controller for R33 series 1 or 2 (i think it can be in both)
Safe tune for minimal mods by simon from Morpowa
Made 210kws at the rear wheels
looking for $1300 to help me fund the new car
pm me in interested
Edited by R33adel
A31 Ceffy, rolling shell, defected
just needs driveline to get running, straight rails
pm me if keen
want it gone to pay for my bike deposit
$900 firm, if you take it this week i will throw in other parts to make the deal more interesting...
pm me for pics....
Anyone? need these gone.
Compaq Presario CQ61-107TU Notebook PC (NW982PA)
RRP is $999. Brand spanking new in box, not even opened or touched. Ill let it go for $800, FIRM.
Specifications can be found here. http://h10010.www1.hp.com/wwpc/au/en/ho/WF...29-3938413.html
PM me or email: [email protected]
its time.
1989 R31 Silhouette Series 3
RB20DET w rb20 box (has been through Regency and registered with the new engine)
Has upgraded brakes, not sure what model, i assume R32.
Chassis 370000ks+
Engine 45000ks
Afterburners (will not seperate)
Alloy rad
FMIC
Aftermarket Turbosmart? blow off valve, plumbed in properly
Battery relocated to boot
remapped RB20 ecu
Jaycar Boost Controller
RB25 turbo (very new!)
some sort of black stockies, rear tyres are worn
Cusco strut brace
CD player, front speakers with tweeters
Aftermarket Guages (volts, oil pressure, water temp, boost (psi), RPM)
Ill throw in some tie rod end spacers for that extra drift lock
Seriously, this car has character. Wind some more boost into this thing and it will be fun on the track, or keep it as your daily. Im selling this due to not selling my 34. I paid $4000 for it not very long ago, ill take $4100 with an extra 3 months rego for you. This is relatively cheap for a registered 31 Silhouette S3 with rb20.
The car is currently draining batteries, i havent had the time to find the source of the problem, but im almost certain its the head unit. You can always disconnect the battery everytime you park it for that ultra ghetto flavour. Keeps thieves from running off with it too. Itll come with an extra battery.
pics:
Serious buyers only please, price is very firm, i just want back what i paid for it.
pm preferred, or 0416 070 133
lol at ^^^
8GB Silver ipod 4th nano 4th gen mint as $125 with free beats :rant:
MB Qaurt reference 6.5 inch splits $175 mint in box
Polk momo mmc650 6.5 inch 2ways $140 mint in box
Pioneer gm-6200F 4 channel amp, had them running 4 speakers, but could run fronts and sub if need be. $175
with wiring kit
all 3 car system $400
or all 4 for $500
Is the clutch out of the car? My gearbox is coming out on Saturday. I'll have a look at the clutch condition, its a extra heavy duty Xtreme single plate with lightened flywheel.
lol
got some pulsar stockies?? i dunno, something stockies, 2 are alloy, 2 are steelies. these fit few cars like old pulsars and hondas etc.
here's their full specs:
Offset: +45
PCD: 4x100
Tyres:
the 2 alloys have 185/60 Bridgstone GRID's with 40-30% tread.
the 2 steelies have 185/60's, with 50-60% tread.
Price:
$100
pics:
Please correct me mods if this is not allowed, didnt see it in the rules.
EOI
R32 GTST 4Door. RB20DET, 3" HKS exhaust, pod, turbo timer, 18" wheels, 4 new tyres last week (235 front 265 rear), Soundstream dvd player, 32 GTR intercooler. Body not bad, 1 chip out of rear bar when I got the car.
Bought for 8k and though I have spent a bit on it im only asking for 8k or a swap offer if it is what im looking for :P
Thanks guys,
nath
pm me in interested
sold pending payment
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
