Xmas specials
- Garrett GT35 Turbo with 0.5 front cover (faster spool then 0.7) and 0.82 rear IW & Custom Braided lines oil restrictor and custom turbo drain etc
Also comes with new 19psi actuator, and hks alloy hard out let elbow to suit. $1700
- Trust Side mount intercooler (uses short piping and goes back into stock piping) $350
- Z32 AFM with plug $200
- SARD 850cc side feed injectors in rail with clips and loom all soldered in $750
- Yellow Jackets coil packs $280 suit r33 series 2
- Apexi Power fc + Apexi Commander with 300kw tune $1300 suit r33
- BLITZ Sbc ID3 SPEC-S Electronic Boost Controller $350
- Nismo 400r Sideskirts suit r33 $200
- Rda slotted rotors & QFM-k750 hight temp pads $400
For sale:
- Nintendo DS Lite, black, brand new unwanted/not needed prize - $100
- HICAS unit, came off a 1998 R33 Series 2 - $50
Also got:
BenQ E2200HD - near new condition - $100
has HDMI input, 22" widescreen, built in speakers etc
Up for sale is my 1995 R33 Series 1.5 Mspec 5sp manual makes 300kw on 18psi
Will make 350rwkw easy with more boost and e85
Price: $19,500 ono
Modifications:
Stock internally rb25det series 2 engine
- Tomei adjustable exhaust cam
- Garrett GT35 Turbo with 0.5 front cover and 0.82 rear IW
- Hpi stainless exhaust manifold
- Metal exhaust gaskets
- Custom Braided lines and turbo drain
- 3.5 "Bell mouth dump front pipe
- 3" Stainless Mandrel Bent Magnaflow cat back exhaust
- 3" Decat
- Silicon Hard intake pipe
- Pod Filter
- Silicon hoses and lines
- Trust FMIC
- Z32 AFM
- SARD 850cc injectors
- Bosch 044 fuel pump
- Exeddy Gtr Cerametallic Clutch Kit
- Lightened Chromolly Fly wheel
- Pro-Stopper Series 5 Alarm
- Triplex Immobilizer
- Head Unit - Eclipise 50x4 CD5444 CD/MS Receiver with MP3/ATRAC3
- Pioneer 6" 4way 280watt fronts
- Kenwood 7x10's 350watts
- Nismo Clear Side indicators
- Kenwood 600w Amplifier
- Kenwood 600 sub
- KYB Coil Overs
- 18" x 9.5 Dtm rush wheels stretched 235's front, 255's rear
- 20% Tinted Windows
- Twin K&N oil breathers
- Water methanol injection
- QFM-k750 hight temp pads
- Custom engineered hicas lock system
post-31991-1259112659_thumb.jpg post-31991-1259112677_thumb.jpg post-31991-1259112687_thumb.jpg post-31991-1259112698_thumb.jpgpost-31991-1259112760_thumb.jpg post-31991-1259112837_thumb.jpg post-31991-1259112876_thumb.jpg
Now 16.5K with stock r33 wheels with semis
r33 series 1 after market front grill (GTR style like the one Talbo was selling a while ago but with the screw tabs)
currently the grill is painted in Wine red
$40 or swap for a standard series 1 grill that is painted black
r33 series 1 coilpacks $120 ono
Danai 0402541975
For sale:
stock r33 dump & front pipe - $30
stock r33 rims and tyres - 2 off - $25 each
r32 seats rear - $250
r32 seats front - $250
r32 gtr gearbox - $500 ono
pickup
gearbox says HXB Nabco japan
pretty heavy tbh, lol. no knees, I could feel it :banana:
Xmas specials
Damn i cant pm yet, but my afm is green and im pretty sure 1993 would be series one
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
