FS: Set of 4x R33 GTR Rims.
Usual suspects: 17x9 +30 Forged rims, perfect upgrade for GTS-Ts or a good set of track rims for a 32 GTR.
All in good condition, only minor rash (1-2cm) on 2 of the rims. Tyres are 235/45/17 all round, pirelli dragons on the front, achilles (I think) on the rear. All tyres have good few mm of tread above the wear bars, so approx 50-60% tread remaining.
Asking $1150
Photo's will be up by the end of the week.
PM me for a mobile number.
Pickup is from Keswick mon-fri during office hours, southern suburbs night / weekends.
Sorry, tyres were Wanli, not Achillies. Photo's below:
For Sale:
2 x Drager X-Plore 5500 twin filter full face masks. Brand new, never used, German made quality. Will include a set of filters for each.
$200 for both or $110.00 each
SOLD Pending payment and pickup.
I have 2 more I had on hold, no communication means these are now for sale too.
for sale:
S1 Stagea / R33 steering wheel with airbag, perfect condition $100
S2 Stagea / R34 steering wheel with airbag and gearchange buttons, perfect condition $100
S2 Stagea / R34 tiptronic shifter unit, perfect condition $80 ono
Mags still for sale now $800
Also have
Blitz turnflow intercooler little damage but was fine on car R33/34 $400
http://i533.photobucket.com/albums/ee334/r...79/P1050560.jpg
http://i533.photobucket.com/albums/ee334/r...79/P1050561.jpg
GFB stealth FX BOV black and chrome $200
http://i533.photobucket.com/albums/ee334/r...79/P1050567.jpg
R33 rear Pioneer splits with crossover 150w 2 way bolt straight in the parcel shelf $100
http://i533.photobucket.com/albums/ee334/r...79/P1050565.jpg
O2 sensor looks brand new $75
http://i533.photobucket.com/albums/ee334/r...79/P1050563.jpg
R33 Strur bar $50
http://i533.photobucket.com/albums/ee334/r...79/P1050568.jpg
R33 nismo side clear indicators exellent condition $60
http://i533.photobucket.com/albums/ee334/r...79/P1050564.jpg
R33 SII AFM pink label has been calibrated with apexi power intake pod filter $150
http://i533.photobucket.com/albums/ee334/r...79/P1050562.jpg
R33 SII 40th anniversery front seats passenger is ex condition driver has small hole in side support from getting in and out of car $150
R33 SII rear seats $100
R33 SII door cards $100
R33 SII rear cards $60
R33 manual radiator $50
R33 white rear tail lights $150
R33 manual ECU SII $100
If there are any other R33 SII parts your after let me know except for the engine and gearbox, bonnet front guards and headlights its all waiting to be removed. And the car was white.
You can PM me or 0427999093
bump front brakes and rotors are sold
steering wheel sold
rear hanbrake cables sold
Hey guys i have a Iphone 3GS 16GB for sale, its in good condition but it has a small crack on the bottom on the back of it as you can see in the photo's supplied. People on ebay are still asking $550 for these second hand but because of the crack im asking $350. It comes with everything that came with it originally.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
