FS: Set of 4x R33 GTR Rims.
Usual suspects: 17x9 +30 Forged rims, perfect upgrade for GTS-Ts or a good set of track rims for a 32 GTR.
All in good condition, only minor rash (1-2cm) on 2 of the rims. Tyres are 235/45/17 all round, pirelli dragons on the front, achilles (I think) on the rear. All tyres have good few mm of tread above the wear bars, so approx 50-60% tread remaining.
Asking $1150
Photo's will be up by the end of the week.
PM me for a mobile number.
Pickup is from Keswick mon-fri during office hours, southern suburbs night / weekends.
Sorry, tyres were Wanli, not Achillies. Photo's below:
For Sale:
2 x Drager X-Plore 5500 twin filter full face masks. Brand new, never used, German made quality. Will include a set of filters for each.
$200 for both or $110.00 each
SOLD Pending payment and pickup.
I have 2 more I had on hold, no communication means these are now for sale too.
for sale:
S1 Stagea / R33 steering wheel with airbag, perfect condition $100
S2 Stagea / R34 steering wheel with airbag and gearchange buttons, perfect condition $100
S2 Stagea / R34 tiptronic shifter unit, perfect condition $80 ono
Mags still for sale now $800
Also have
Blitz turnflow intercooler little damage but was fine on car R33/34 $400
http://i533.photobucket.com/albums/ee334/r...79/P1050560.jpg
http://i533.photobucket.com/albums/ee334/r...79/P1050561.jpg
GFB stealth FX BOV black and chrome $200
http://i533.photobucket.com/albums/ee334/r...79/P1050567.jpg
R33 rear Pioneer splits with crossover 150w 2 way bolt straight in the parcel shelf $100
http://i533.photobucket.com/albums/ee334/r...79/P1050565.jpg
O2 sensor looks brand new $75
http://i533.photobucket.com/albums/ee334/r...79/P1050563.jpg
R33 Strur bar $50
http://i533.photobucket.com/albums/ee334/r...79/P1050568.jpg
R33 nismo side clear indicators exellent condition $60
http://i533.photobucket.com/albums/ee334/r...79/P1050564.jpg
R33 SII AFM pink label has been calibrated with apexi power intake pod filter $150
http://i533.photobucket.com/albums/ee334/r...79/P1050562.jpg
R33 SII 40th anniversery front seats passenger is ex condition driver has small hole in side support from getting in and out of car $150
R33 SII rear seats $100
R33 SII door cards $100
R33 SII rear cards $60
R33 manual radiator $50
R33 white rear tail lights $150
R33 manual ECU SII $100
If there are any other R33 SII parts your after let me know except for the engine and gearbox, bonnet front guards and headlights its all waiting to be removed. And the car was white.
You can PM me or 0427999093
bump front brakes and rotors are sold
steering wheel sold
rear hanbrake cables sold
Hey guys i have a Iphone 3GS 16GB for sale, its in good condition but it has a small crack on the bottom on the back of it as you can see in the photo's supplied. People on ebay are still asking $550 for these second hand but because of the crack im asking $350. It comes with everything that came with it originally.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
