some bits and pieces for sale that ive had hanging around (and the sheds getting a bit cluttered)
pics on request (i have some but camera batteries went flat).
contact via PM or my number if u have it
R32 GTR interior
Interior trim parts that ive removed from my race car
Carpet
B pillar trims
C pillar trims
Rear 1/4 window trim
Rear seats
Front seats (located at virginia at the current moment)
Boot carpet
Boot plastic trims
Boot "floor"
Headlining, door trims, map light, interior light and dash still in place for now. Parcel shelf is already sold
Looking at $900 for the lot (or will work out deals for someone who doesnt want everything)
Other parts
R32 GTR FRONT only brakes (Sumitomos)
Rotors (reasonable meat left), calipers, pads (condition / brand unknown), stock lines
$300 negotiable
HKS Mechanical gauges (52mm)
Oil Pressure, Oil Temperature and Water Temperature
Complete with wiring for lighting. One gauge (oil temp i think) doesnt light up, didnt ever check why)
No instructions, but i know which temp gauge was which lol
$200 for the lot
HKS recall / warning boost gauge (big motherf**ker)
With lines, wiring etc, no instructions but the important wires seem to be the longest
$100
Mines "LCD boost meter"
pretty flash looking jobbie, digital boost gauge readout. LCD on the display is slightly damaged, but still reads alright
comes with control box and wiring, just plug boost line into the back of it
$80
Blitz BOV mounted to a solid pipe (S13 CA piping apparently). Never used since i bought it at Drift Supercup second hand off a trade stall
$100
Interior parts now down to
Front Seats ($600 for pair, $400 each)
Rear Seats ($350)
Rear under window trims ($50 each)
Ohter parts still available
For sale as a package is the following
Uniden "Bearcat" UBCT-8 250 Channel Scanner (pre-programmed for Metro SA)
GME AE4018K1 antenna with 3ish metres of cable (and plug)
Small external speaker and cable
Plug will need to be re-soldered onto the cable as thats the only way i could remove the antenna from the car
Scanner also comes with small telescopic antenna (for out of vehicle use) and 240v power adapter
Pre programmed for metro Adelaide (and you get lucky about 100km radius on occasion) with:
SA Ambulance Service
SA Metropolitan Fire Service
Country Fire Service
State Emergency Service
plus airband channels for Adelaide Airport and Parafield Airport
programming was done by Electric Bug at Croydon
pic of it as in car, fits nicely in a DIN slot with no need for mounting bracket (firm fit)
best pic i can find of it, below CD player
more details about the unit itself can be found here: http://www.uniden.com.au/AUSTRALIA/p_ubct8_index.asp
$250 NEG. still in the car, but most of ya have seen me playing around with it ;)
all parts off my running rb20 motor:
turbo no shaft play$100
alternator :$60
starter motor:$40
power steering pump$:40
coil pack loom:$40
engine loom:$100
ignitor:$60
plus other random stuff: http://nissansilvia.com/forums/index.php?s...=0#entry5965949
DEFECTED 4door 32
fruitylicious-PERFECT TRACK WEAPON
ENGINE
-120,000 klms
-custom turbo ( ats )
-greedy fmic, truck clamps
-Earls oil cooler an relocator
-dose pipe, afm relocated
-screamer am, strate pipe
-power fc an controller
-hks evc5
-adjustable cam gears inlet an ex
-walbro pump
-brand new headgasket, belts and lines
SUSPENSION
-npg coils in front
-isc in rear
-whiteline front an rear sway, extra bracing
-strut brace front an rear
-brake stopper
-33 lcas
-hicas lock
-kkr camber
-kkr castor
INTERIOR
-kenwood mp3
-kenwood speaker fr an rear
-greddy indiglo boost gauge
-shift light
_FREEZING COLD AIR_
EXTERIOR
-weathershields
-custom 1 of side skirts
-pods
-custom front bar
-roof wing
-passenger side rear quarter seen a white reflector post !
JUST SERVICED WITH ALL FLUIDS AN EXPENSIVE OILS , oil changed monthly til now
Asking $10k will remove parts to make cheaper or swap for stockish S14
PLS ME ME IF INTERESTED !
Edited by PROXIMITY
you cant legally sell a defected car
of course you can otherwise wreckers would be empty it can be sold to make a track car or to be parted out . ive bought a defected car and had the defect removed and the rego changed over with the old owners help .
nothing is impossaible
He said legally though Adrian was warned by the po po for buying and selling a defected car. We all know theres ways around most things.
you can legally sell a defected cars to the wreckers . you can legally sell a defected car if it's not going back on the road . and we all the know the po.po aint right all the time every time :-)
1- Blackberry storm 9500.
had for about 12-13 months. works perfectly fine, never had an issue. its a vodafone locked. only selling due to getting a iphone4.
comes with box, leather case, charger, mini usb cable and all the manuals and CD.
$200.
2- Blackberry Pearl
used this for about 12months. been sitting in the box for another year (2 years old)
same as above, works perfect. comes with box, charger, usb, manuals and CD.
$100
i can mms pictures to anyone interested.
pick up can be arranged from west subs or meet somewhere close.
or buyer pays post.
cheers,
Adrian
Apexi dual N1 exhaust, decided to go back to my old single 3 1/2", has small dent on center muffler but still in excellent condition. Excellent exhaust, great flow and sound $550.
http://www.apexi-usa.com/products/?id=5509
Best to message with the hours im working. 0413 697 162
Still up for grabs
Hey guys I have a shed full of stuff I no longer need so have a look through and see if theres anything u need and give me a text, call or pm if u are interested in an item/s.
GENERAL ITEMS
1) mint full set of Buddy Club P1 racing wheels in hypermax gold with good condition Kumho KU36 semi-slicks all round plus Work annodized valves. $1300.
17 x 9 + 37 & 17 x 8 + 32 255/40/17 & 235/45/17
2) full set of ISC N1 coilovers for R33 GTS-T. 12kg front, 8kg rear. Immaculate condition, recently purchased and stripped off a car I bought. $800
3) pair of 25mm spacers (5 x 114.3) $90
4) Immaculate condition Garret 2871R "disco potato" for SR (no lines included) $800
R32 ITEMS
1) RB Nismo Super Copper Mix rigid Clutch plate with Nismo 860kg Heavy duty pressure plate with RB fly wheel $350 post-4555-1290052740_thumb.jpg
2) L/H front vent for R32 $50
3) R32 GTR door trims $90
4) pair of R32 stock front lower control arms $30
5) pair of R32 stock rear upper camber arms $30
6) pair of R32 stock front castor arms $20
7) R32 stock side mount cooler $20
8) R32 GTS-T stock rear wing (silver) $10
9) R32 glove box $20
10) R32 driver and passenger interior front section (above door) $30
11) R32 stock orange side indicators $15
12) R32 dash cluster $50
R33 ITEMS
1) R33 series 1 afm with pod filter $50
2) R33 series 2 afm $50
3) pair of R33 stock front castor arms $20
4) R33 glove box. immaculate condition $30
5) R33DET (RB25) Tailshaft $90
6) R33 interior gearboot and surround $30
7) R33 drivers side dash vent $50
8) R33 centre dash vent $80
9) RB25 aftermarket manifold (brand new) $200
10) RB25DET Series 2 coilpacks, mint condition, $80 (all 6)
11) R33DET stock diff, condition like new $90
12) pair of R33 rear drive shafts (rear axels) $100
13) R33DET power stearing rack $50
14) R33 centre consol $40
15) R33 driver and passenger interior front section (above door) $30 post-66618-1290053617_thumb.jpg
16) R33 rear interior upper section $40
18) R33 dash cluster $50
19) R33 series 2 engine x-member plus brackets (lowest RB engine drop / conversion for silvia) $180
20) R33 rear cradle (all arms - no hicas, hubs, diff or axles) $150
21) R33 brake package, mint with plenty of meat (all 4 rotors, hubs, calipers, knuckles and front uprights) $700
22) R33 stock exhaust manifold $20
23) R33 front strut brace $15
24) R33 rear strut brace $15
25) R33 passenger side front guard (white) $30
26) RB25DET series 2 Ecu $100
27) RB25DET standard clutch, pressure plate and flywheel (condition like new) $150 msg-34341-1290061343_thumb.jpg
28) RB Nismo Super Copper Mix rigid Clutch plate with Nismo 860kg Heavy duty pressure plate with RB fly wheel $350 post-4555-1290052740_thumb.jpg
Please contact me on 0400 259 598
Cheers
Chris
for sale:
bosch 044 $180 brand new
enkie 17 x 9 or 9.5 unsure, say: bnr33 n1 racing inside
with 4x bridgestone re55 semis slicks. just above wear bands and a fair few good laps in them if rotated correctly
currently fitted maxxis z1, fronts pleanty of meat. rears about 2mm above wear bands.
$1800 ono for rims with tires + very good semi slicks
for sale, pm me please:
1x single working rb26 r32 gtr afm air flow meter, $70
one pair slotted 280mm discs, suit r32 gtst or stagea s1, $50
one pair rear Skyline/Stagea/Silvia/300zx braided brake lines, adr tag approved, Maltech brand, fits nissan, tighten up rear brake feel, $100
1x r32/33 passenger Bride seat rail, $120
clean rear r32 seats, with seatbelts, $40 bargain
rear r32 wing, grey with LEd brake light, $20
RPM 5-point racing harness, 3" straps, $50
ZX9R Ninja stock exhaust muffler, $50
POST UPDATED WITH SOME PICS
R32 GTR interior
Rear 1/4 window trim (lower rear passenger trim)
Rear seats
Rear trims - $70 pair
Rear seats - $250
Front seats - $500 for pair or $350 each
Other parts
$300 negotiable
$200 for the lot
$100
$80
$100
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
