R32 GTR Trust Jasma Exhuast 3" Cat back, also have larger front pipes(inc cat) to go with sale(not sure if trust front pipe though)
Cat back is all heat wrapped
Reasonable cond, has had some ressy swaps in its life, but passed with 89db at regency on mine.
$250, northern suburbs
sms or pm
0413 247 219
700cc SARD injectors to suit RB26
Excellent condition, only 3500kms of use.
Injectors will be available after March 6th.
With Bosch 044 and Sard Regulator these have supported 430rwkws at Factory base fuel pressure / pump fuel.
$550 - Western Suburbs
Fitting available for a little extra.....
PM me
I have a full set of S14 seats if anyone wants them? Upgrade your shitty S13 or R32 seats! Comes with rails and seatbelts if you want them as well
$250, take front and rear off my hands!
HSD HR Coilovers - $1200.
AMPerformance Full Stainless Steel Exhaust - Split Dump, straight though with HFC & Blastpipes - $1100.
Full R34 Nistuned ECU - $500+Standard Ecu.
Velo Podium 2 Fixed Bucket Seat With Mounting Bracket - $1000.
Bronze Work Xd9's 18x9+30 18x10+18 - With current tires and a spare - $2200.
Factory Option R34 Fourdoor Monsoon Shilds - $300
KKR Pineapple Bushes - $60
12" Soundsteam Taranchula Subwoofer inbox - $300
Contact via PM or 0432 581 798
PM me
Just tried to Pm you but it didnt work, was going to ask you if the above your selling, would they fit in a rb25, thanks.
1) Item: R34 GTR Spoiler (Genuine)
Item Condition:
Good condition, Pearl White in colour, missing the adjustable part of the spoiler. (Can get carbonfibre copys of it)
Contact Details:
PM me
Price and price conditions:
Looking at 550 negotiable
2) Item: R34 4 door factory nissan side skirt LH
Item condition:
Good condition couple scratches and one crack where it goes into the wheel bay/arch area (apparently very common)
Navy blue metallic in colour
Contact me via PM
Price: $200
Located in WINGFIELD
1) Item: Cannon IP4300 duplex printer
Item Condition: Good condition, 1 of the black ink cartridges needs replacing pronto
Contact Details: PM me or ring me 0421932750
Price: $60 firm
http://www.canon.com.au/ftp/pixma%20ip4300%20techsheet.pdf
2) Item: Diamondview Flatbed Scanner
Item condition: Good condition
Price: $25 fairly firm might come down if you buy either or both other items
3) Item: Pro Color Compatible ink cartridge 2x Black large and small cyan magenta and yellow and the chip reseter
Suits: PIXMA iP3600/ iP4600/ ip4700
MP540/ MP550/ MP560/ MP620
MP630/ MP640/ MP980/ MP990
MX860/ MX870
Item condition: Brand New
Price: $45
Factory RB25 are side feed and GTR are top feed injectors, need to convert to top feed rail and need resistor pack as well. It can be done but I'll default to RB25 guru's to confirm.
ADR Monza fiberglass recliner with 180sx/s13
Decent condition just a little faded.
$150 with rail!
RS*R Front pipe suit 180sx/s13 with some 3" split dump pipe (think the dump pipe has a crack)and a dead o2 sensor still init.
$50 for it all
180sx old school bird bath wing painted in champagne. Paint and wing are in great condition and fit perfect.
$100
PRICE DROP!!
HSD HR Coilovers - $900.
Bronze Work Xd9's 18x9+30 18x10+18 - With current tires and a spare - $2000.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
