up for sale is my little bro's s15
P plate friendly jap spec s15 (non turbo)
just under 91 000kms
auto
everything completely stock besides the cannon muffler
will come with s15 stock rims
not realy much else to say about the car
PRICE $11800
any questions please pm me or text on 0415 23 23 97
car is located in mansfield pk S.A
my R33 Gtst is forsale, looking for $16 as is, ill add more pics to the main section when I get time.
price is negiotable depending on what state of tune it is in. Be nice to sell as is on E85, with a nice fat 350-380 rwkw.
Ill be running it at the dyno day if not sold before!
please pm or text/ring for more details.
0403302513
cheers
cleaning out the shed
r32 radiator with shroud and hoses $150
r32 clutch fan $50
r32 2 door taillights $60 pair
r32 a/c condensor $70
r32 a/c compresor $80
r32 gearbox mount $50
r32 clutch slave cylinder $40
r32 stock rear swaybar $10
r32 stock intercooler $20
r32 dash pretty good condition small bubble,was going to keep for my car but cant be botherd $50
r32 power steering pump hicas $40
r32 gtr ignitor $40
r33 drivers door with window silver $100
r33 gearbox mount $50
r33 standerd boost solinoid $40
r33 gearbox tailshaft yoke cut off $50
r33 manaul peadal set $40
r33 washer bottle $20
r33 stock intercooler $20
r33 rear cradle with all arms and hicas $150 or $25 a arm
r33 starter motor $50
r34 manaul pedal set $40
r34 a/c compressor $150
r34 5 bolt drive shafts $70 pair
s15/14 washer bottle $40
s15 front swaybar $50
s15 front crossmember $40
s15 drivers side splash sheild $50
s15 brake master cylinder abs $60
s14 sr stock intercooler $30
s14a front bar with indicators $100
s13 sr radiator with shroud and hoses $60
issota red steering wheel $50
blitz turbo timer $20
can mms pics located sa athol pk 0422030855
up for sale is a r33 gts rolling shell for drag/drift only has sunroof
no interior missing bonnet + front bar, lights
it has a few small digs on it nothing major
4 stud gts brake (not 5 as show)
asking for $400
text me on 0430606223
SOLD SOLD SOLD
R33 Genuine Hybrid FMIC (600x300x76) and Piping kit. Note that intercooler hot size pipe has a small gash/hole (about 1cm long by 2mm wide) and would require welding to fix prior to fitment, or you could clamp a silcone joiner over the gash. Price reflects this.
$250 - pickup from NE 'burbs.
Edited by Ionos
PRICE DROP ON MOST ITEMS
RB25det sump $30
R33 sr2 wing needs paint $30
GTR wing no end caps needs painting $160
R33 Air Conditioning Condenser gtst 1994 $35
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 climate control $35
R33 gtst fuse box and cover $20
R33 gtst sr1 bonnet hinge set $15
R33 gtst overflow and washer bottle $25 for both
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $55
R33 gtst battery tray need painting $10
R33 manual gear shift boot/plate $20
RB25 R33 GTST SR1 CAS CAM ANGLE SENSOR AND BRACKET $45
R33 clutch master cylinder $30
R33 RB25 skyline power steering reservoir with lines $20
RB25det fuel rail $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
R33 Air Conditioner Compressor with lines as seen in pic $55
RB25det sr1 aac valve $40
r33 gtst sr1 carbon bonnet $400
fiberglass vent (uncut vent) $55
rb25 turbo 45v2 has a blown seal $50
R33 gtst sr1 abs unit and bracket $60
R33 gtr intercooler (corrosion on bottom)$35
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $90
r33 horns $10
r33 sr1 bonnet in primer has a few scratches and a small dint from sitting in the shed $120
catco high flow cat 2.5inch 325mm long $50
apex rb25 front pipe 2.5inch has a few dings $100
Nismo muffler 2.75mm inlet with 4.5inch tip $150 plus rear section that suits r33 free with muffler
PICS http://www.skylinesaustralia.com/forums/topic/364044-shed-clean-out/page__st__20
pm me or 0435888239
Will post at buyers expense
Dave
Complete stock rb25det
Includes the following:
Rb25det series 2 engine
Tomei adjustable exhaust cam pulley
Stock exhaust manifold and turbo
Dump front pipe
Cross over pipe
Intercooler & Pipes
Complete series 2 loom to suit
Series 2 ecu
Brand new bosch belts
Brand new water pump
post-31991-0-29761900-1309769029_thumb.jpg post-31991-0-93154400-1309769062_thumb.jpg
Had a slight bottom end noise when cold, ran really well starts first time, turbo is in new condition no shaft play
$1000 the lot or will separate
Edited by FOOLBOOST
Up for sale is my 1995 R33 Series 1.5 Mspec 5sp manual
Car makes 260rwkw on only 15psi, has the following mods:
Rb25det Series 2 engine
· 3" Stainless Mandrel Bent Magnaflow cat back exhaust
· 3" Dump front pipe
· 3" hi flow cat
· Twin 2.5” Stainless rolled tips
· Pod Filter
· Silicon hoses and lines
· Bosch 044 fuel pump
· Exeddy Gtr Cerametallic Clutch Kit
· Lightened Chromolly Fly wheel
· Pro-Stopper Series 5 Alarm
· Triplex Immobilizer
· Head Unit –Pioneer 50x4 DEHP5150USB CD/MS Receiver with MP3/ATRAC3 USB
· Pioneer 6" 4way 280watt fronts
· Kenwood 7x10's 350watts
· Nismo 400r Sideskirts
· Nismo Clear Side indicators
· Kenwood 600w Amplifier
· KYB Coil Overs
· 20% Tinted Windows
· Twin K&N oil breathers with fliters
· Custom engineered hicas lock system
· Nolathane bushes
· Z32 Air Flow Meter
· New Frount Mount intercooler
· New High flow turbo (Rb25det turbo 21U Hypergear highflow gt3076 core)
· New Remaped ECU
· Manual Boost controller
· 18x9" ROH Drift R wheels with near newYokohama Advan Semi slick 235/40/18 all round!
post-31991-0-65905000-1309828262_thumb.jpgpost-31991-0-25592500-1309828294_thumb.jpgpost-31991-0-60952700-1309828370_thumb.jpgpost-31991-0-56840200-1309828412_thumb.jpg
Is capable of 285-300rwkw with more boost, see attached dyno charts, car is stealth under the bonnet as to not attract the wrong sort of attention.
Very fast street car not for the faint hearted, would do excellent track / quater mile times too. Great for street daily driving or tracking when you want to have some fun
Car starts first time every time, is in excellent condition as per pics, reason for sale is have purchased a track car.
Note wheels not included(avaliable for purchase), will come stock r33 ones
13k
Pm with enquires
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
