awesome value right there I can vouch for that product
I ran about 13.7 psi daily for about 3 years reliably
Matty see Martin when your ready to set it up I'm sure he would only charge what a power run would be worth 1 hour on the dyno at max so that may be between 70-150$
disclaimer obviously I am not the dyno operator and aforementioned price is only a guide/guess
Seems like the right idea. When they did my power fc we had some dramas with the boost control kit, so gareth put a manual bleed valve on and had it on and off the dyno in a matter of minutes! We had gone through alot of s**t and it was a dream come true to finally have the car running tip top. Above all that, no charge for dyno and i had to make gareth take a $50 note for the bleed valve! 10/10!
Back onto topic.. R32 GT-R factory front grille still for sale.. $150 (silver, perfect condition)
Also SRI hicas lock bar and bypass hose kit to suit s13/r32
Unused, still wrapped..
$100
FOR SALE: CP Pistons Sets-Nissan Skyline rb25 or rb26, 86.5 Bore
Features include:
- High strength aluminum forgings
- Super lightweight designs
- Fully CNC machined and balanced to +/- 1 gram
- Wrist pins included at no extra cost
- Accumulator groove included
- Double pin oilers, force fed from oil ring
- Pick lock grooves for easy lock removal
Comes Complete with:
(6)Pistons
(16)Locks
(6)Wrist Pins
(6)Piston Ring Sets
CP Pistons Sets-Nissan Skyline, part# sc7308
im asking $850 ONO, no reasonable offers refused
any questions please PM me, sms or call me on 0439262702
ARP NISSAN RB20 RB25 HEAD STUD KIT
THIS KIT COMES WITH: STUDS, WASHERS, NUTS, AND ASSEMBLY LUBE.
TO SUIT:
NISSAN RB20DE, RB20DET, RB25DE, RB25DET
Replace your stock head bolts with ARP heavy duty head studs. The stud design helps the head and the block equalize the pressure better thereby creating a much more even and consistent seal. It is recommended to replace the head studs/bolts with a new set if the head bolts are ever loosened due to metal fatique. Reusing an old and possibly warped or stretched head bolts/studs will sacrifice the seal between the head and block and may cause head gasket leak. This is a great an easy upgrade when doing an engine rebuild or building a race motor.
the studs are still in the box and have never been used,
im asking $200 ONO, no reasonable offer refused!
any questions feel free to PM me, txt or call me on 0439262702
RB20 - RB25 - RB30 main and rod bearing kit, .25 ovesize
ACL RACE SERIES PEFORMANCE BEARINGS
THIS KIT PRICE IS FOR A FULL SET OF MAIN BEARINGS AND CONROD BEARINGS THEY ARE STILL BRAND NEW AND STILL WRAPED IN THE FACTORY PLASTIC
BEARINGS ARE .25 OVERSIZE
$200 ONO, NO REASONABLE OFFERS REFUSED!
ANY QUESTIONS PM me, TXT OR CALL ME ON 0439262702
FOR SALE:
- HIS IceQ X Radeon HD 6950 - pretty much BRAND NEW as I've only taken it out of the box, fitted it up, havent powered up as I was short a PCI-e power cord(was going to get another one today but something has came up and rather the money) - I paid $291 posted a few days ago so it's under warranty and have receipt to prove - selling for $250 firm
Prefer SA buyers for the following to save postage so will post it up here and will open it up to interstate buyers in a few days
- rear upper adjustable camber arms to suit R32 GTR/GTST and maybe other Nissan models - $100
- pair of NISMO N1 turbos to suit RB26DETT, made 270rwkw @ 13-14psi - still on the motor, will have it out within the next day or two - $900
Expression of interest for now - let me know if you're keen, may or may not sell but currently very likely:
- RB26DETT cam covers, spark plug cover and timing belt cover - $350
- RB26DETT head - $800
Any questions feel free to PM me!
Selling a Greddy Emanage Blue.
- Universal Fuel / VTEC Harness.
- Laptop Cable
- Injector harness
- Ignition Harness
- Various connectors, cable-ties etc
- Warranty Card
http://www.ebay.com....=item2567593ce1
If a SAU member wants to pick it up before it sells will do for $300
for sale SR20DET complete engine minus turbo .Has all manifolds stater coil packs alt exhaust everything had slight bottom end noise when pulled out only 120xxxx on clock would say conrod shell bearing. want it gone need shed space and engine stand back for the RB 25.:thumbsup: $450
R33 gtst complete diff and craddle minus brakes and hubs $150 ono front cross member minus hubs and brakes $50 also a set of bilstiens for r33 say $100 ono
cheers
bilstiens and front cross member sold
cheers
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
