E-manage Blue, no harness but does come with software and cable. I will even throw in a USB to serial adaptor that works with the unit. Unit is in good working order. Looking for $300 ono.
Plug in GReddy E-Manage ULTIMATE Harness N-9, to suit Nissan Silvia, 180SX, S13, SR20DE(T) 1/91 > 7/96. Brand new, has never been installed. Asking $100
For Sale
R32 GTR Front Grille in silver. perfect condition ( also have brand new clips for it) $150
SRI Hicas Lock Bar will fit r32 or s13 with bypass hose kit (Brand New, still in wrapping) $100
Set of HKS style split dump pipes to suit rb26. $100
PM, call/text 0457408477 can send pics if required
RB25det sump $30
R33 sr2 wing needs paint $30
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 bonnet hinge set $15
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
R33 Air Conditioner Compressor $40
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts(not sure if its complete) $50
R33 gtst sr1 air con units that sit behind the dash $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25
vr v6 commodore sedan fuel sender and pump(pulled from running) $40
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $15
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 gtst R/H drivers door glass $40
R33 gtst L/H drivers door glass $40
R33 rear window $70
R33 gtst front fenders rolled and liped $170 for both
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50
R33 gtst false rear wall $20
R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50
RB25det stock dump on black vht $20
R33 gtst rear bar with gtr pods both will need repair $50
r33 gtst sr1 power window motor regulator LHS $80
r33 gtst sr1 power window motor regulator RHS $80
R33 gtst rb25det hicas computer $60
ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project)
ARP rb25 Exhaust Manifold Kit new never used $100
items FOR SALE:
  • Twin tip straight pipes made from high grade stainless steel $150 firm designed to be flanged under the sub frame/ diff originally came from exhaust technology. very good quality pipes. suits R32.May suit other Nissan models.
  • Apexi ECV (Exhaust control valve) suits 3" exhaust system quietens the exhaust right up for street, especially when po-po are around.Used condition $150 firm very good condition comes in original box complete. well worth the coin.
  • Standard r32 GTS-T series 2 steering wheel (rare with leather horn button not plastic black one) mint condition no rips or tears,stitching is perfect $150 firm best you will find pics on request.
  • Standard r32 RB20DET injectors x 6 $100 firm come complete with o rings and seals, came off my 20 for GTR injector upgrade last kms was about 115,000. Good condition no leaks.
  • Midnight blue R32 GTR front bar (not N1) genuine plastic with genuine un cut GTR reinforcement, factory mesh and number plate bracket and custom made tow strap fits between lip and bar $600 firm will not split. sold as a package.
  • Original side repeaters mint condition on fascia sides x 2 one has broken top clip supplied needs plastic welding $100 for both or $50 each. Not supplied with globes and holders.Suits replacement.
  • Genuine din pocket with spring loaded front cover flap fits in center of dash near climate control and cd player. suits r32 skyline $30 mint condition
cheers guys please call me or text me on 0421675373 if there are any questions or interest. Im not on here alot anymore :(
regards BEN.
Edited by BENDERS32
Hey all,
offered to SAU south australia first!
Up for sale is my manual '91 gts-t. I want a 4wd so i can play in the mud... this has to go! It has been sitting in the shed with a vacuum leak (now fixed) for a couple months, been riding the bus like a boss to work and i really don't need it
The bad first, damage to the passenger side front guard, needs a fresh clutch as the one in there is slippery as all hell, its out of rego, the starter soilenoid is dead and it wants a new –ve battery cable, so it aint going anywhere at the moment under its own steam. Not much to fix i know, but im done sinking $ into it.
only defect it has had since coming over from VIC 5 years ago is for bald tires
Has the following bits:
Tein HR's
Apexi 3" Turbo back exhaust with cannon
RB25 series 2 turbo
Splitfires
Front & rear strut braces
ISC 52mm radiator
Trust/Greddy GREX filter relocator
Shimmed LSD
Genuine GTR front bar (has scratches on the passenger side)
Type M skirts and rear pods (pods arent on the car at the mo)
TOMEI 300kmph speedo
Sparco rims (17x8 front and 17x9 rear)
Falken ZIEX 235/45/17 all round 99% tread
Also have some spare bits in the shed that will go with it:
Replacement passenger side guard (small amount of damage ie. less than the panel on the car :P)
Stock radiator
Oil cooler + relocator & fittings
Various suspension bits
TEIN C spanners
And whatever else i find
The Car will be sold AS IS.
$5000 ONO
PM ME FOR MORE INFO
but right now its in the shed looking like this:
Greddy Emanage Ultimate with universal harness.
Bought second hand, never fitted, now plans have changed and I'll be running something different.
I believe it's off an R33 with an RB25DET map on it, but I'm not sure. Harness looks unused.
$400, might even drop it off if you supply the beer! :thumbsup:
Can vouch for bezenders car, sounds awesome coming on boost and looks pretty decent in the flesh too.
Ive got a new stainless steel RB25det exhaust manifold to sell.
Clear-coated it in exhaust heat paint and wrapped it in thermal wrap. Since taken off the thermal wrap, and as such got some fibres stuck here/there.
Definately in as-new unused condition. Cost me $300 a couple of years ago, sell for $150. Currently sitting in the car at Boostworx - hope to have it in my possession again this week sometime(?)
Decided to use the stock manifold and sell this aftermarket unit on.
Also have a Stagea cargo barrier next to sell - $100 ono, comes with stock swaybars and stock front brake discs (used)
Plus selling some old holden "fat" rims with tyres for my dad
ebay link here: http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&item=290619421625&ssPageName=ADME:X:RTQ:AU:1123
$100 for the set of 4. Suits FJ, FX, EH, EK, etc.
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Hey mate any way of grabing clutch pedal set asap
Ok I have a r32 4 door minus front seats, motor, diff, trans, front bar, and bonnet. Everything else is In perfect condition. Parts for picking guys. And I have a spare rb20 head up for grabs 2. SMS or call 0433370776.
i have a set of braided lines for turbo.
2 water lines and 1 oil.
both banjo bolts for the water.
all you need is copper washers and its a complete set.
used for 50km's
then upgraded to speedflow lines and fittings.
$130
Hey all,
Tein HR's
RB25 series 2 turbo
Splitfires
ISC 52mm radiator
Shimmed LSD
Stock radiator
TEIN C spanners
$5000 ONO
PM ME FOR MORE INFO
DEPOSIT TAKEN
stock RB26dett turbo dump pipes (pair), with stock twin turbo 2-1 front pipe (from dump to cat converter)
$50 pickup, Morphett vale. Will throw in used RB26 stock oil pump.
rb25det exhaust manifold as posted above, make an offer. Advertised for $150 but will sell at the right price.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
