Got some stuff sitting here doing nothing:
3inch cannon, unsure what brand, no dents or huge scratches but used not new. $40
Twin 3" straight pipes, 3" inlet also.
Bought for $120 a month or so ago and ended up with a stainless exhaust, so price is $120 firm.
N1 GTR spoiler "Carbon fibre look"
Cost me $300+ postage off Just Jap. Save on postage $300 pick up, Brand new!
http://justjap.com/store/product.php?productid=17338&cat=&page=2
2X 235/45/R17 Federal 595-SS, above wear indicator still good for a few skids $80 for both
Kicker 'comp' Sub & Amp. $300
Kicker Sub and Amp comes with all wiring and everything you need to hook it all straight up, sounded really good when I had it in the other car, has a proper Kicker ported box and all Kicker wiring also.
Selling for $330 at JBs (without full wiring kit, fuses etc I'll give you with it!)
http://www.jbhifi.com.au/car-sound-gps-navigation/sub-woofers/kicker/amp-sub-box-combo-sku-73622/
Was only used for around 6 months!
Pics:
[/quote
Bump!
R34 Parts For Sale:
Pink Label AFM - Perfect working order $50
R34 Airbox & Snorkel with a ryco panel filter $50
RB25det Neo Coil Packs - Perfect working order $80
Stock Cat - $50
Rubber Intake Pipe - $20
Stock Fuel Pump - Perfect working order $30
Front Seats - Will sell as pair only $200
Generic Parts:
Slip on spacers 8 or 10mm $10
1 din triple gauge mount $10
HKS Turbo Timer $25
Samsung Omnia Icon 2 I8000T Mobile with ac charger $120
Parts all located in Clearview (near Gepps Cross Int).
All Prices are ONO so make a offer,low balls will be ignored.
Pics/inspections available on request.
Contact:
PM on here
or
0432 838 323
Daniel
Edited by funki_munki
s2 rb25 (not neo) splitfires with braket and loom - $sold
r34 GTT front brakes inc: calipers, rotors (dba4000 slotted), pads (a1rm). rotors and pads under 500kms old - $600
eboost boost controller with solenoid, wiring and vac hose - $300
99% brand new r32 gtst BC br coilovers - $1000
1.5L surgetank ($150), 044 pump ($200), magnaflow fuel filter ($150), lines and fittings - $sold
r32 early style brick headlights (n1 looking without the brakets for n1 vent) with globes and wiring - $150
pm and i can txt pictures.
Blitz Nur Spec exhaust 3" stainless cat back to suit r33 comes with 3" cat $350
Tow bar to suit s2 stagea, comes with wiring plug and fittings $250
s2 stagea auto centre console $70
s1 sagea auto trans with MV automatics shift kit $400
AVS wheels 17x8 and 17x9 with 235/40 all round heaps of tread left $450
s2 rb25 550cc injectors in standard rail $350
Still for sale:
Sorry some of the pictures are as links, wasnt letting me post pictures properly.
New N Spec water pump (R33 GTR) - 200$ (Top in the picture - Unsure if it suits other models apart from R33 GTR) - Brand New in box
New East Bear clear front indicators (R33) - 150$ - Brand New in box
Indicators 1
Indicators 2
More info on indicators here
http://www.nengun.co...stal-indicators
Greedy Oil Catch Can - 150$ (Used for 1 month - comes with original packaging etc)
More info on catch can here
http://www.streettun...-/prod_342.html
Isotta Steering wheel Perfect Condition - with Boss Kit (came off Silvia) - 80$
Steering Wheel
Can call/text on 0408 370 576 - Pickup from Hindmarsh / CBD
R34 Parts For Sale:
Pink Label AFM - Perfect working order $50 SOLD
R34 Airbox & Snorkel with a ryco panel filter $50 SOLD
Stock Cat - $50
Generic Parts:
HKS Turbo Timer $25
Contact:
PM on here
or
0432 838 323
Daniel
R34 Parts For Sale:
Stock Cat - $50
Generic Parts:
HKS Turbo Timer $25
Contact:
PM on here
or
0432 838 323
Daniel
Pic of the left over items. Just a note,the seats are from a sedan not a coupe,pics of these shortly.
R32 GTR front seats - including adaptor for drivers seat to fit 180SX etc (can still fit R32 GTR) $600ono good condition
R32GTR Jap tuned factory computer - no speed limiter / boost cut lifted. Made 270rwkw with STD turbos at 21psi....perfect for the Garrett dash upgrade turbos! $300ono
5 Point Safety 21 Roll Cage (Half Cage) for R32 GTR / GTST. Blue padding, includes mounting bolts. $700
Bump it up!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
