Items for sale, out of the car and ready! Some pictures at the bottom.
R33 s1 RB25 motor, comp test: 145 150 150 145 155 150 comes with computer loom and aftermarket coilpacks, no manifolds, very healthy motor - $1500 make an offer
R33 s2 manual gearbox 85,000km old, smooth, can do as a manual conversion kit $1800 (everything you need but no clutch) or alone $1500
ORC (Ogura Racing Clutch) 409 series single plate, couple track days old however Ive never driven on it so I dont know condition, un-sprung center and stock pedal feel - $400 (what it owes me)
R33 9 point Cusco D1 cage, side intrusion bars, through dash, all plates and bolts included - $950
AM performance R33 - GTS/GTST/GTR exhaust, comes with de-cat, split 2.5" system in to in built resonators and 4" twin pipes out with titanium tips - $1000
R32 GTR Intercooler - $150
400r R33 side skirts - $120
400r R33 rear bar, been cut out for larger exhaust but can be re-fiber glassed or exhaust shield made to cover (hence price) - $120
R33 genuine plastic front bar, damaged, no cracks in plastic good for drift - $120
R33 genuine front indicator covers and indicators - $80
R33/34 GTR Auto Select Tower Bar
As Topic States:
I have an Auto Select Raised SPL Type Tower Brace to Suit R33 & R34 GTR (Not R32!)
(pretty sure it suits all r33/34 variant as the strut towers are the same...)
Trial fits welcome...
This Auto Select Skyline GT-R strut tower brace is pure porn, its a wide, thick and strong item that substantially increases stability between the upper suspension mounts. This has the effect of keeping alignment setting stable as the body cannot flex under stresses of cornering.
Drivers of cars fitted with these items immediately notice more responsive handling and more direct steering. They also can remove some rattles and squeaks from older vehicles by increasing chassis rigidity.
This Auto Select brace is machined from high grade T6 Aluminium in a single piece for ultimate strength. Light weight is maintained by removing excess aluminium and this also gives a benefit of an improved look with the AS logo machined into the face of the bar. It is now lighter and stronger than before.*
Other company’s bars and braces are of no comparison. This one is the best available.
The Auto Select Bar wraps around the strut towers for extra support. Thats why the Nagisa Auto R34 Demo car also uses this Auto Select Bar.
Selling as i would like to purchase an R32 GTR Item new as these are very rarely offered secondhand.
Price: $725 Pick Up. $750 Delivered
(Over $1100 outlayed for this originally & will again to get one to suit my R32 GTR).
(Check Below Site for New Price)
http://www.neweraparts.com/Default.aspx?tabid=54&List=0&ProductID=892
Actual Pics (On my R32 GTR to show why i cant reuse this item).
In case anyone think you can just reverse it 180degree amd make it fit...
Nope...It Doesnt work!!!
The angle of the Coilover Mounts are out by about 35ish degrees...
Moreso than that, the brace mounts are moulded around (actually wrap around) the top of the strut towers...
Below is a pic of the Centre Bar & the 2 different types of mounts, R33/R34 (Left) & R32 (Right).
(shows difference in angle & tower mould...
Underside shot showing tower moulding...
Motivational pics:
Contact: PM
Edited by krayzie32
17x8 Drift R's for sale.
Good condition
Good tyres, only fitted a few months ago, 2x sumitomo zII & 1x Maxxis MA-V1 & 1 random due to puncture in other maxxis
Some gutter rash but overall good condition
After $500.
FOR SALE
custom lobster back rb26 twin turbo pipes
lightly polished aliminium 60mm pipe
increases torque and response, reduces back pressure in in the cooler pipes
made to fit 34 gtr but should fit any rb26
pipes are as is, dont come with silicone joiners
after $400, will fit them at no cost but need joiners
post-9995-0-97881100-1333146607_thumb.jpgpost-9995-0-04491200-1333146800_thumb.jpgpost-9995-0-61878300-1333146816_thumb.jpg
R33 s2 headlights excellent condition all brackets no fade etc - $350
33 s2 1997 gtst rear cradle with diff, complete rear hubs n brakes and manual tailshaft - $350
s2 KR4 both Doors with full trim/glass/mirros but missing power window switch - excellent condition, also kr4 boot with s2 spoiler - $500 the lot will throw in some freebies.
Also have a complete s1 gtst head with most boltons still attached.
Edited by KISIN
Update:
R33 s1 RB25 motor, comp test: 145 150 150 145 155 150 comes with std. computer and aftermarket coilpacks, no manifolds or loom, very healthy motor - $1500 $1300
R33 9 point Cusco D1 cage, side intrusion bars, through dash, all plates and bolts included - $950 sold
AM performance R33 - GTS/GTST/GTR exhaust, comes with de-cat, split 2.5" system in to in built resonators and 4" twin pipes out with titanium tips - $1000 $950
R33 gtr genuine plastic front bar, damaged, no cracks in plastic good for drift - $120 on hold
R33 gtr genuine front indicator covers and indicators - $80 on hold
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
