urgently need a drivers side door for a silver coupe. please pm if you have one or know someone who does. Cheers
Chuck it on the Wanted To Buy thread of the SA section and or the main section as well. You will be surprised as to how quickly you might find something by posting on there.
Clarion double din dvd player
Touch screen, used but in good condition, comes with Jap to Aus aeriel adapter
$200 firm
or swap for FMIC for Stagea/R33 or a new version EBC (can give cash your way for the right stuff)
Details/pics here -
http://www.clarion.com/au/en/products/2009/multimedia/multimedia_source_units/MAX386VD/au-en-product-pf_1172419833216.html
$200 firm
Details/pics here -
I tried to pm you but it wouldn't work.. If you could message me on 0414450101 cheers I'm keen
all gtr stuff For sale
jdm r32 GTR adjustable front and rear brace.
the orange ones with skyline written on them.
100 each
kakimoto stainless steel front pipe for twin turbo rb26's - $200
stainless steel cat back 3inch exhaust with 1 muffler looks standard but sounds amazing - $200
apexi pod filters - $225
pictures available on request
all the stuff is still on the gtr will take off when bought .
only PM me.
thanks
225/45/17 tyres, decent tred on all 4 would say atleast 65% or more from memory. 200 bucks for all of them, so 50 bucks per tyre, slightly negotiable.
4x r33 stockies, 2 bald tyres other 2 at about 50% approx, 250 bucks ono. bit of gutter rash.
series 1 r33 drivers steering wheel = got no idea so bidding starts at 50?
r33 series 1 interior, 2x set of front seats, one in better condition than the other, both have wear marks/hole in drivers side, but one is substantually less than the other, rear seat top and bottom bit, doorcards (unknown/cant remember condition) rear quarter cards must go.
60 bucks per set of front seats or grab a whole interior, front seats rear seats, door and quarter cards for 120 or the lot for 150, need it gone as im getting stuck for space.
series 1 rear spoiler, not needed anymore, kh3 colour code (black) 10 bucks ono, want it gone taking space, may even let it go as a freebie if your quick enough.
pm me on here or send me a text on 0422360999.
cheers all, aaron
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
