r33 rear strut brace $100
r33 silver s2 rear wing $40
r33series 1 headlights no broken brackets not foggy need a polish if your fussy $250
r33 gtst front calipers and rotors $250
aftermarket purple fuel rail to suit rb25 with greddy style plenum $50
r33 A pillar plastics $20 pair
Surge tank round polished single outlet bottom $70 (going duel outlet surge if someone wants to swap?)
stock rb25 cross over pipe with stock bov $20
GT3076 front and rear housings (5 bolt .63 rear) $150 the pair
r33 stock thermo $20
Hey got a few bits for sale
Rb20det low mount stainless turbo manifold,new never fitted
$150
Brand new Bosch
040 internal fuel pump
$200
R32 GTR nismo strut brace
Matt black colour with brake master stopper
$150
R32 front camber arms
Fully adjustable
$150
Rb26 rocker covers (stock black)
Coilpack cover (blue needs paint)
Nitto clear cam cover
Rb26 cam gear backing plate
Everthing you need to bolt them to your rb20
$500
Blitz I-d SBC all parts you need to install in your car
$350
Alpine type s
15inch subs x2
$500 pair or $250 ea
Part no... sws-15d2
Hks timing belt
$150
S13/r32
Solid subframe bushes
$100
R33 turbo
Front calipers
$150
R33 bn side skirts and
R33 bn rear bar
Suit 2 door coupe
$350
R32 gtr front brakes
$300 complete
R32 gtst front brakes
$200 complete
Got a bran new apexi data logit that im looking to sell as im thinking of selling my power fc too.
Its so new i havent even plugged it in and used it yet. Comes complete with everything needed to use the program.
$300 I can post if need be at your expence.
RB25DET r33 turbo with oil and water lines. Good condition the usall slight shaft play. Doesn't blow smoke. Due to upgrade i no longer need. $300
RB25DET exhaust manifold. Due to a GTSR manifold i no longer need. $100
RB25DET standard injectors with out rail. Upgraded to larger items. $100
RB25DET inlet manifold. Doesn't come with throttle body or tps. Going ffp so i no longer need. $80
All items are for a S2 motor. If serious please pm me.
Adam
Bump make offers
4x varrstoen 2.2.2 19x10.5 +15 in chrome
4x kuhmo ku36 275 semi's
4x toyo r888 295 6-10 laps (near new)
$2400 the lot
kakimoto cat back stainless steel (full mega n1 +rev model) very near new immaculate and sounds tough
$750
r32 headlights x2
$200
contact via pm
cheers
HKS GT2535 Full Kit for R33 RB25DET. Great condition with minimal shaft play, about 50,000kms travelled and plenty more in it. Ready to bolt straight up to your GTS-T.
Includes turbo itself, elbow and silicone joiner/shield, all lines, basically everything you need to swap out with your standard turbo. I'll include some new turbo to manifold bolts. An easy 250-260rwkw with supporting mods.
$800 ono. Pickup from 5098. Makes me sad I pulled it off the car at this price.
Adam
Nissan R33 Gts-t Cushion Button Clutch
Just came out of my R33 gts-t and has plenty of life left in it. Only been in for about 15,000kms and car has only been used as a daily (female driver). Was only taken out to be replaced by something lighter for everyday use. RRP: $535
Looking for $150
i assume that will hook up ok to a 34gtt, with a 33 manual box?
how much heavier than a normal HD clutch,
ive had a ceramic button clutch in my 32 which just didnt work in traffic
sorry dont mean to hyjack
how was it to drive in traffic? cussion buttons i thought wer ok, what was it replaced with
I didn't notice it any more to be honest, got used to it quickly but had to pull it out anyway while doing the gearbox, so just put a new Exedy heavy duty back in. Wasn't much point having it in when I only go to and from work.
Looking for $150
SOLD
HKS GTSS .64 housing
good condition, suits SR20 or CA18
was run on my CA18DET and made 180kw on 14psi, could easily make 200kw with more boost and is very responsive
$600
Bride rix reclinable
comes with rail to suit s13
has a few tears
$250
Hi Guys
Im selling up my parts I had planned to go onto my 180SX. Its a complete bolt on high mount turbo kit. All the parts needed are in this kit so its ready to bolt on and tune.
All parts are new and never used, some have been bolted to my engine but then removed without being started as Im selling everything including the car.
Kit consist of the following,
Kinugwaw TDO6SL2-20G T3 8cm V band exh housing external gate with complete braided line fitting kit and all nuts, bolts, studs and gaskets needed.
Tial 38mm MVS wastegate in black.
Kelway high mount T3 steam pipe manifold
Kelway s/steel dump/front pipe with removable wastegate return to convert it to a screamer when the need arises
Kelway 3 inch aluminium turbo intake pipe with NEW silicon joiner
Kelway 2 inch aluminium turbo outlet pipe with NEW silicon joiner
New oil drain and cam cover hoses wrapped in NEW Aeroflow silicon heat sleeve
Aeroflow NEW fittings to adapt the water lines to the turbo so they fit neater than the supplied Kinugawa gear
So its a complete kit with the only thing you need to add to is a manifold gasket if you dont already have the re-usable S15 style gasket.
This complete kit cost me $2700.
Price $2350.
Bosch ID 1000cc top feed injectors with loom plugs. set of x 4. NEW never used.
Price $460
Aeroflow billet top feed fuel rail kit for S13 SR
Comes with NEW Aeroflow fuel fittings to connect it all up.
Price $180
Turbosmart FPR 800 adjustable fuel pressure reg with Turbosmart fuel pressure gauge and Aeroflow fitting to connect it all up. All parts NEW.
Price $220
Send me a PM if your keen on any parts.
ALL LOW BALL OFFERS WILL BE IGNORED
Cheers.
Bump people.
Will take $2100 for the turbo kit. Need it gone ASAP.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
