GT32 Posted February 19, 2011 Share Posted February 19, 2011 (edited) Moved thread from the For Sale (Private Whole cars only) section to here as it was more appropriate since i ended up deciding to strip the car instead (http://www.skylinesa...-S-t340489.html). Everything has basically been copied and pasted from the previous thread and is currently up-to-date. However, i have removed the Work wheels/nuts/hub rings from the listing as i have decided to keep them for the new car. PM me if you want further information on any parts or i can be contacted on 0488 188 111. Pictures can be found on my blog - http://vrsatyle.word...09/14/for-sale/ ENGINE: RB30/25DET LONG MOTOR - $N/A DUAL-CORE ALUMINIUM RADIATOR WITH 2X 12" THERMO FANS - $250 NISMO R32 GT-R IN-TANK FUEL PUMP (276L/HR) - $350 MALPASSI FUEL PRESSURE REGULATOR (RISING-RATE = 1:1) - $100 TWIN-ENTRY FUEL INJECTOR RAIL (TOP-FEED) - $100 SIEMENS 740CC FUEL INJECTORS (TOP-FEED/HIGH IMPEDANCE. INCLUDES ALL PLUGS/COLLARS/O-RINGS) - $350 GREDDY OIL CATCH CAN - $80 SOLD BRAND NEW APEXI GT SPEC RADIATOR CAP - $50 ENGINE MANAGEMENT: APEXI POWER FC WITH HAND CONTROLLER (AP ENGINEERING/HCR32) - $1400 INDUCTION: GARRETT GT3582BB (GT35R) 700HP DUAL BALL BEARING TURBO (0.82 A/R) - $1100 SOLD / PENDING PAYMENT 6BOOST RB25DET HIGH-MOUNT EXHAUST MANIFOLD (TUNED LENGTH) - $900 CUSTOM VMS MOTORSPORTS BAR AND PLATE FRONT-MOUNT INTERCOOLER (680X280X120MM) - $300 DRIFT HIGH-FLOW POD AIR FILTER - $50 NISSAN Q45 THROTTLE BODY - $100 SOLD NISSAN HCR32 AIRFLOW METER - $100 EXHAUST: TIAL 44MM EXTERNAL WASTEGATE - $350 SOLD / PENDING PAYMENT CUSTOM DUMP PIPE TO SUIT GT35 (HPC/CERAMIC COATED) - $200 SOLD / PENDING PAYMENT CUSTOM FRONT PIPE - $80 SOLD / PENDING PAYMENT HIGH-FLOW CAT - $100 SOLD GARRETT GT35 TURBO BEANIE - $50 SOLD TANABE TUNER MEDALLION RACING CAT-BACK EXHAUST (3.25" SYSTEM/4" EXIT) - $400 DRIVETRAIN: RB25DET GEARBOX - $1000 SOLD CUSTOM 1-PIECE TAILSHAFT - $100 SOLD NEW EXEDY HD BUTTON CLUTCH (UNCUSHIONED)/MACHINED RB25DET FLYWHEEL (TRAVELLED 2.5KMS) - $550 USED EXEDY HD BUTTON CLUTCH (UNCUSHIONED)/USED RB25DET FLYWHEEL (TRAVELLED 8000KMS) - $200 SOLD USED RB25DET OEM FLYWHEEL - $50 INTERIOR: BRAND NEW APEXI AVC-R ELECTRONIC BOOST CONTROLLER (BLACK) - $600 APEXI TURBO TIMER - $50 APEXI S-AFC AND APEXI S-ITC - $150 RECARO SR2 RACING BUCKET SEATS (REPLICA) - $500 SOLD EXTERIOR: GENUINE NISSAN R34 CLEAR SIDE INDICATORS/WINKERS - $50 SUSPENSION: TEIN HR-SERIES ADJUSTABLE COIL-OVER SUSPENSION - $600 R32 GT-R FRONT AND REAR STRUT BRACE - $100 SOLD ROLLING SHELL WITH REGO UNTIL MAY 2011 (VEHICLE COMPLETELY STRIPPED. WILL SELL WITH FULL BODYKIT/BRAKES/DIFF/FACTORY R33 GTS-T RIMS/FACTORY SUSPENSION/FACTORY ECU): - $3000 NEGOTIABLE Edited February 19, 2011 by GT32 Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/ Share on other sites More sharing options...
TJR32GTS-T Posted February 19, 2011 Share Posted February 19, 2011 (edited) *recomended seller* gearbox is still going strong mate cheers again. i think i might grab your injector setup off you in a couple of weeks if they havnt sold by then. also what kit is on the rolling shell? are you willing to separate it? - trent *edit probs should have looked a the pix before asking, will you separate the kit? Edited February 19, 2011 by TJR32GTS-T Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5677926 Share on other sites More sharing options...
GT32 Posted February 19, 2011 Author Share Posted February 19, 2011 Hey dude, Not sure of the exact brand but people have told me it's an ECCS front and rear bar. I haven't seen alot of these kits around. Infact, i've only ever seen two R32's with this exact same kit (one in VIC and the other in QLD). I'm trying to sell the rolling shell with the bodykit intact at this point in time but if anything changes i'll let you know asap. With my RB25 injector setup you might need to change to a forward-facing plenum and use an aftermarket RB20 top-feed fuel rail to make them fit as i'm not entirely sure that they will be a direct replacement on the standard fuel rail (can someone please confirm this?). In theory, they are technically compatible as they're both high impedance and top-fed but making them fit into the standard fuel rail could be a different story. When i purchased them for my RB25DET head i already had a new plenum and fuel rail installed so we never got to test compatibility. I'll do some research later and get back to you. Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5677985 Share on other sites More sharing options...
TJR32GTS-T Posted February 19, 2011 Share Posted February 19, 2011 Yeah sweet man, let me know about the kit cos I'm pretty keen on it. Keep me posted Cheers-Trent Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5677996 Share on other sites More sharing options...
GT32 Posted February 21, 2011 Author Share Posted February 21, 2011 The rolling shell still comes with the complete interior minus the front seats. I've had quite a few people ask me about this so just thought i'd clear it up now. Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5680246 Share on other sites More sharing options...
GT32 Posted March 1, 2011 Author Share Posted March 1, 2011 Couple of price updates as i really need these gone. RB30/25DET LONG MOTOR (NEEDS NEW OIL PUMP AND CRANK COLLAR) - $1750 NEGOTIABLE ROLLING SHELL WITH REGO UNTIL MAY 2011 (VEHICLE COMPLETELY STRIPPED. WILL SELL WITH FULL INTERIOR MINUS FRONT SEATS/FULL BODYKIT/BRAKES/FACTORY R33 GTS-T RIMS/FACTORY SUSPENSION/FACTORY ECU): - $2500 NEGOTIABLE Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5693871 Share on other sites More sharing options...
d_soljah Posted March 1, 2011 Share Posted March 1, 2011 message pics of the shell to 0431 121 625, is that price including the interior body kit and so on ? Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5693941 Share on other sites More sharing options...
GT32 Posted March 1, 2011 Author Share Posted March 1, 2011 (edited) message pics of the shell to 0431 121 625, is that price including the interior body kit and so on ? G'day mate. I'll take some new pics and mms to your mobile by tomorrow arvo and yes, that price includes everything that i mentioned in my last post still intact on the car. Engine loom is also still intact. You can see pics of the body from when the car was still running by going to my blog via the link in my signature or you can scroll up to my first post in this thread and click on the direct link to the pictures from there. Edited March 1, 2011 by GT32 Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5693971 Share on other sites More sharing options...
GT32 Posted March 2, 2011 Author Share Posted March 2, 2011 message pics of the shell to 0431 121 625, is that price including the interior body kit and so on ? Mate, just tried to MMS the pics of the shell to your phone but on my side it keeps saying failed. Have you received them? If not, give me your email addy and i'll send them through there instead. Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5695781 Share on other sites More sharing options...
GT32 Posted March 2, 2011 Author Share Posted March 2, 2011 NISSAN HCR32 AIRFLOW METER - $100 SOLD Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5696322 Share on other sites More sharing options...
GT32 Posted March 2, 2011 Author Share Posted March 2, 2011 Just removed this evening. NISSAN HCR32 FACTORY V-LSD DIFF - $250 Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5696329 Share on other sites More sharing options...
GT32 Posted March 3, 2011 Author Share Posted March 3, 2011 Removed this from the list as i've decided to keep it and re-use on the new car. NISMO R32 GT-R IN-TANK FUEL PUMP (276L/HR) - $350 Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5697409 Share on other sites More sharing options...
Mosullivan Posted March 3, 2011 Share Posted March 3, 2011 Details of the engine? Internals etc? Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5697456 Share on other sites More sharing options...
GT32 Posted March 3, 2011 Author Share Posted March 3, 2011 (edited) Details of the engine? Internals etc? G'day mate, Had a quite a few people asking about the motor so i'll just copy and paste the info from a previous enquirer... ===================================================================================== "Not sure if you read my previous thread before i moved it over to here but the motor has a failed oil pump. Happened right after we installed the new clutch during idle when we were warming it up to give it a test drive. We noticed the oil pressure light had activated and we shut off the engine asap. Didn't have the car on for very long (~30secs) so i don't think it would've done any damage. I spoke to a few different workshops and they told me pretty much the same thing that the bottom end bearings will be fine as it happened during idle. Motor has done roughly 8000kms. Max power it has made so far is 297rwkw @5800rpm/17.5psi during the run-in tune. We backed off at 5800rpm due to a faulty bleed tap boost controller not controlling the boost properly so i purchased an apexi avcr to replace the manual bleed tap controller and have the car retuned as the engine was pretty much run-in and due for its final tune. Obviously that never happened. We were hoping to make around 330rwkw on 20psi and rpm set to no higher than 6500rpm. It was built by Ron Hutchins from Ronny's Performance Motors in Newtown, Geelong (parent company - Geelong Engine Replacement Services Pty Ltd). Engine was tuned by Raymond Ong from Auto Racing Technik (A.R.T.) in Heidelberg West. I don't have the build receipts with me but can request the original receipts from Ronny's Performance Motors at anytime. Engine specs are: Series 1 RB30E short block with turbo oil feed and return separately drilled and tapped Series 1 RB25DET cylinder head - reconditioned, ported and polished (VCT retained) Standard series 1 RB25DET camshafts/valvetrain Chemically cleaned, torque plate bored and honed block Block 20-thou overbore Compression 8:1 Wiseco forged pistons Chromoly piston rings Crack-tested RB30ET rods Machined RB30ET crankshaft Bottom end completely balanced ARP head studs, main studs and rod bolts Genuine nissan engine bearings throughout Genuine nissan RB30ET oil pump Genuine nissan RB30ET water pump To have it back up and running requires a new oil pump (i recommend an RB25DET oil pump) plus a new wide-angle crank collar (from proengines.com.au) as i suspect that the pump failed due to wear and tear of the narrow factory RB30 crank collar hence not driving the pump. It comes with the PWS/air con pumps and alternator plus coil packs and ignitor still intact." ===================================================================================== Edited March 3, 2011 by GT32 Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5697496 Share on other sites More sharing options...
GTEES Posted March 3, 2011 Share Posted March 3, 2011 photo of the front bar? Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5698198 Share on other sites More sharing options...
GT32 Posted March 7, 2011 Author Share Posted March 7, 2011 Also removed this from the list as it's going on the new car as well. BRAND NEW APEXI AVC-R ELECTRONIC BOOST CONTROLLER (BLACK) - $600 Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5702401 Share on other sites More sharing options...
GT32 Posted March 8, 2011 Author Share Posted March 8, 2011 Price drop on the AP Engineering PowerFC as i want it gone. APEXI POWER FC WITH HAND CONTROLLER (AP ENGINEERING/HCR32) - $1400 $1200 Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5705249 Share on other sites More sharing options...
snakeman Posted March 10, 2011 Share Posted March 10, 2011 do u still have the APEXI S-AFC AND APEXI S-ITC Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5708442 Share on other sites More sharing options...
GT32 Posted March 11, 2011 Author Share Posted March 11, 2011 do u still have the APEXI S-AFC AND APEXI S-ITC Sorry mate, they're currently on hold for someone until further notice. Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5709192 Share on other sites More sharing options...
GT32 Posted March 15, 2011 Author Share Posted March 15, 2011 (edited) APEXI POWER FC WITH HAND CONTROLLER (AP ENGINEERING/HCR32) - $1400 $1200 SOLD Edited March 15, 2011 by GT32 Link to comment https://www.sau.com.au/forums/topic/354442-parting-out-modified-hcr32-skyline-rb3025det/#findComment-5714002 Share on other sites More sharing options...
