I've just experienced a water pump failure on a track day. Stock-type aftermarket RB30 pump, total running km about 2000. The bearings collapsed, skewing the rotating bits and the pump seized/spat water out. No issues with overheating prior to it failing, and the water picked up on rear tyres caused an off track excursion so problem identified quickly.
The question for all 30DET builders who use theirs for regular track work is - what spec pump did you use, and have there been any other similar failures?
I'm considering whether the RB30 pump is not suitable, even with a 7200rpm hard cut, and driver-imposed limit of 6500? Other than the price difference, an N1 can go in but if I've just copped a crap pump then will replace it with another stock type.
https://www.sau.com.au/forums/topic/354697-water-pump-options/
The failed pump sitting in front of me has an 8 bladed impeller.
A GMB branded (Made in Japan - reputedly good quality) pump Part # WP898 from Repco has a 6 bladed impeller but looks otherwise similar. The shape of the backing area is smoother, but not flush-fitting as the N1 design appears to be from pics I have seen.
Less blades should be more efficient at higher pump speeds, and maybe not quite as good at lower speeds, same principle as per turbocharger impellers.
Pics of the N1 looks like it is a better piece of kit altogether but I think its pointless spending the extra if the majority are running stock-type pumps without problems.
So what does a stock RB26 water pump's internals look like?
Edited by Dale FZ1
I think it might depend on what batch of impellers they had available. The one I saw had 6 blades. Genuine pump from Nissan spares had 8, same as the original pump on my RB25, and the failed aftermarket pump. The general finished quality of casting etc on the genuine gear looks higher too; that's what I went with, not going to have another event spoiled if it was a case of inferior quality.
Front of the engine is reassembled, waiting for spare time to install the radiator and add water this week.
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
